Scanmaster readings, normal?
Old 03-17-2013, 03:38 PM
02v8ta's Avatar
Default Scanmaster readings, normal?
Ignore my company in the video....
where are you at Ed?
Edit; I guess I was just expecting any knock retard to happen under load and not idling.
Old 03-19-2013, 02:51 PM
unioncarpenter84's Avatar
mine does the same thing is this true or is it false knock??
Old 03-19-2013, 10:34 PM
cardo0's Avatar
Default Has the computer had a tune?
Values are opposite of expected. It goes lean at 3500rpm with zero retard. Then back to rich at idle with retard - where it normally uses advance without load.
Take a look at the rpm and see if it matches your tach - scanmaster may be connected wrong.
Interesting to follow this thread and to see how the scanmaster works - like i can't tell which O2 it reads, right or left? But its really nice to have that info right on the dash real time - if/when it works. Could be cool tool.
Thx for posting,
cardo
Old 03-20-2013, 09:15 AM
02v8ta's Avatar
Thx for posting,
cardo
Thanks ill have to check what rpm the scanmaster is seeing.
Glad I'm not alone.
Old 03-20-2013, 09:23 AM
wrd1972's Avatar
Mine does not do that, its zero at idling 99.9% of the time. Anytime I did notice KR at idle, it was always exhaust related like a pipe hitting the chassis. Might put a wide band O2 on it to determine accurate A/F.
I seriously doubt this is a connection issue.
Old 03-20-2013, 09:27 AM
02v8ta's Avatar
The exhaust is something ill be messing with soon anyway probably but I didn't notice any contact with the headers and the body. Right now it's just LTs x pipe dumped at the rear.
Old 03-21-2013, 05:51 PM
ya mine exhaust never hit it seems like after u run the car for thirty minutes and it gets warm then u sit there it says a couple of degrees
Old 03-21-2013, 07:09 PM
9-Second Club
Ed Wright's Avatar
It would be tough to make one detonate at idle. It is most certainly false knock. If a cammed car does that the tuner has his head up his butt. Don't care how loud it is.
Old 03-21-2013, 07:18 PM
ya pcmforless did mine and they even deconizatized my knock sensor
hey ed if i buy tuner cats or a cable could i send my tune to u with out sending u the pcm??
Old 03-21-2013, 07:20 PM
02v8ta's Avatar
Pcmforless did mine as well on this car.
Old 03-21-2013, 07:23 PM
9-Second Club
Ed Wright's Avatar
I'll get another *** chewing if I answer you. LOL
Old 03-21-2013, 07:24 PM
ya i dunnno what there doing wrong. ur car isnt at 180 in the pics
we gotta solve this some how
Old 03-21-2013, 07:25 PM
haha by who?
Old 03-21-2013, 07:33 PM
9-Second Club
Ed Wright's Avatar
Whoever runs this place. I'm not a sponsor.
Old 03-21-2013, 11:02 PM
fex77k's Avatar
Ed did my pcm, my scanmaster never did anything crazy at idle.
Old 03-22-2013, 01:04 PM
02v8ta's Avatar
How do i retrive the codes using the scanmaster? The website with the info on them isn't working for me and i don't recall how.
Old 03-23-2013, 12:05 AM
cardo0's Avatar
Default Turning the engine off erases all stored data.
Mode button is on the left. Press the Mode button to identify the mode and the right display shows the data.
I won't post the instruction manual in case of copyright law. But i can PM u with the instructions in plain text if u want.
cardo
Old 03-23-2013, 03:26 PM
ya if there are any codes it will say dtc on ur left and the code on the right
Quick Reply: Scanmaster readings, normal?
