Explain half filled block
Old Mar 29, 2013 | 02:40 PM
93Euphoria's Avatar
Default Explain half filled block
Ok so im a newb to big power applications and know that filling the block will make it stronger but does that mean you cant daily drive it or on the street? Would it mess up coolant passages? Just wonder because one day ill be in the crowed of 1000+RWHP LT’s
Old Mar 29, 2013 | 02:54 PM
F0x Slaughter's Avatar
People run half filled blocks on the street.
Old Mar 30, 2013 | 11:01 AM
I8ASaleen's Avatar
I don't really see the purpose for it on our blocks. Unless you are running huge power or very thin cylinder bores, you shouldn't even have to consider it.
Edit: just saw ur 1000hp comment. What combo will you go with for that?
Old Mar 30, 2013 | 09:50 PM
93Euphoria's Avatar
Im also curious how well Stock gear driven water pumps hold up on 1000+rwhp LT’s. With all the 1000+hp LT’s ive seen went to electric water pump.......
Old Mar 30, 2013 | 10:35 PM
96capricemgr's Avatar
what is your concern? The stock waterpump moves more water at mid and high rpm than the electrics.
Old Mar 30, 2013 | 10:52 PM
Why are you concerned about it it not holding up anyways?
600hp at 3000rpm is the same at 100hp at 3000rpm to the waterpump.
Its about the rpms.
Old Mar 30, 2013 | 11:05 PM
93Euphoria's Avatar
Its about the rpms.
Just curious if enough power could strip the water pump drive gear or if im just paranoid?!
Old Mar 30, 2013 | 11:08 PM
tt383lt1's Avatar
just run a electric. i like mine on the street the hottest mine gets is around 205 and I'm not running hardbloc in my engine and i ran 28psi last year. and maybe going higher this year.
Old Mar 31, 2013 | 09:39 AM
Puck's Avatar
Its about the rpms.
Being cam driven it is exposed to the torque of the engine. They have been stripped and/or broken in the past, and I wouldn't risk it. With a 1,000 HP build I would definitely be ditching it for an electric setup.
Old Mar 31, 2013 | 11:12 AM
SS RRR's Avatar
Village Troll
Its about the rpms.
I disagree. I believe it's about how that RPM is reached.
Old Mar 31, 2013 | 11:15 AM
fex77k's Avatar
I would only fill the block if I was close to the water jackets on the bottom end, If you clearanced the block for a 4" crank it would be real thin in some areas. There is several different methods to the fill, short and a full fill. If you are serious about 1000hp I would expect it to have at least a small fill and there is no way you would be running a stock waterpump if you have a front mount power adder(you can get away with a stock pump if you aren't trying for 1000). You will have to either move the cut radiator support to stand the radiator up, or fabricate an entire new frontend support.
In short a fill is just a little bit more insurance if you are stuck running a non aftermarket block.
Old Apr 1, 2013 | 03:41 PM
93Euphoria's Avatar
Yeah thats what I figured. So LT1’s have so many limitation but with a 1000hp build and how much heat they generate how well do electric WP cool an 1000hp LT?
In a nutshell how good would an EP hold up on the following:
-Lots of abuse Daily Driving
-Long Highway trips
-Plenty of high RPM racing
-Highway racing
-Sustained high rpms for long periods of time (considering more heat, and less water flow)
-Driving back home from the track
Basically having the freedom to do whatever the hell you want like you would if you had an 1000hp LSX still being tame as a cat and reliably evil like a dragon....
Old Apr 1, 2013 | 04:30 PM
Who look at Mr Analogy over here.
Old Apr 1, 2013 | 05:50 PM
93Euphoria's Avatar
Lol no need to be a smart***. Just wondering what is possible and what is not. Nothing wrong with being alert before
Old Apr 1, 2013 | 06:06 PM
tt383lt1's Avatar
what r u doing? turbo, supercharger, nitrous?
you just have to insulate your exhaut good and get a nice radiator and cooling fans. with shields but i have no idea on the exact hp on mine but at 10 psi i had 720rwhp and at 28 psi it still cools fine and i run a electric water pump.
Old Apr 3, 2013 | 01:24 AM
fex77k's Avatar
You would need a over sized cooling system if you are going to run any motor at high load for extended periods. You would also require a substantial fuel system and extra capacity oil system. There is really only one option, an FI motor air to water.
Old Apr 3, 2013 | 03:27 PM
93Euphoria's Avatar
Thanks on the insight! Im assuming the stock water pumps are good to about 700hp?!
Old Apr 3, 2013 | 05:52 PM
fex77k's Avatar
I don't know what the stock limit is, but I would run a good one and not the cheap china just that most parts stores are passing off.
Old Apr 3, 2013 | 07:48 PM
pillarpod's Avatar
daily driving a 1000hp really?
Old Apr 4, 2013 | 12:29 AM
93Euphoria's Avatar
Its been done before.....
