Best Mild Cam?
I picked up 63rwhp over the stock cam with the only changes being cam, valvetrain and a tune. Fat torque curve too. Easy driveability, pulled 6th from 60mph willingly with stock 3.42s. I had the pill set at 6500, but that cam peaked at about 6100 or so. The numbers were 352/365 SAE through shorty headers and full catback.
Keep in mind the stock LT1 head stops increasing flow at 0.5" lift - so higher lift cams gain u nothing (even with better vlv springs) but may even lose charge velocity. Yes they may make even less power. Just google for any stock LT1 flow bench numbers. The LT1 stops at 0.5" (or maybe even less) with 'bout 215-220 cfm intake flow. No more at 0.6" on intake or exhaust.
Now using the "stock" LT4 cam with 1.6 rockers adds lift while keeps it less than 0.5". Or the "Hot cam" without the 1.6 rocker arms would be <0.5" lift but even tighter lobe separation angle and more duration and work fine with the stock LT1 head.
Let us know what u expect for "mild".
cardo
cardo
A lot of these other cams aren't exactly mild too imo, if mild its what you want check out the crane 227.
TA Moscow: a lt1 tuning legend is in this thread, pm Ed Wright, I'd link you to his site but I'm on my phone. Hit him up tho, he'l cut you a tune n then you can datalog it, send Ed the info and he'll tweak the tune as needed.
got the cai and the trick elbow instead of spending money for nothing
next i think will be Mac mid headers and the 2400 stall. And only after those upgrade i will be thinking about cam and heads with ported intake.
next i think will be Mac mid headers and the 2400 stall. And only after those upgrade i will be thinking about cam and heads with ported intake.and if your looking at mild cams... the cc 304 is almost unnoticeable... many people mistake my car for stock
lol
