Best Mild Cam?
Old Apr 2, 2013 | 02:52 PM
SwampWS6's Avatar
Default Best Mild Cam?
Whats the best mild cam suggestions for a stock 97 LT1 T/A WS6?
Old Apr 2, 2013 | 04:48 PM
Bomber Z's Avatar
That's hard to say because everyone's opinion is different to what is mild. To me for a street driven LT1 the CC305 is a great choice. I had the 304 and it was an improvement over stock but did not meet my wants in power. I just put in CC306 to match the AFR heads better. The CC305 in a stock LT1 has great power. I would also get a tune and up grade the valve train. IE springs, roller rockers, push rods. This is just my .02
Old Apr 2, 2013 | 05:15 PM
myltwon's Avatar
CC503 gets my vote, ran great with my stock heads motor. Honestly didn't lose to a single cam-only LT1 in my area when I had it.
Now if you want to go beyond off-the-shelf check out AI or LE.
Old Apr 2, 2013 | 07:17 PM
Fazz73jr's Avatar
CC503 gets my vote aswelll
Old Apr 2, 2013 | 08:41 PM
TravisMcGill2000's Avatar
Cc 503. Or custom grind
Old Apr 3, 2013 | 06:15 AM
96lt1m6's Avatar
Lpe 211/219
cc 503
Old Apr 3, 2013 | 03:48 PM
ABA383's Avatar
LPE 211/219 is a great choice. I ran that cam in my old 383 for a while and it was a great choice. Its a terrific small cam.
--Alan
Old Apr 3, 2013 | 08:55 PM
Catmaigne's Avatar
What mods do you have? You don't just throw a cam at a stock motor or it will drive and perform like crap.
Old Apr 3, 2013 | 10:50 PM
cardo0's Avatar
Default Ok, mild.
U want mild? Try the LT4 "stock" cam - more lift, more duration, tighter lobe separation. But u will need to replace the vlv springs. The stock vlv springs aren't strong enough to handle the LT1 cam at high RPM. But LT4 vlv springs are cheap too.
Good luck,
cardo
Old Apr 4, 2013 | 05:02 AM
96lt1m6's Avatar
Lt4 330hp cam is hardly worth the swap.
1996 Y-body, 1996-1997 F-body: 200/207 0.447/0.459 lift 117 LSA. 1 1996 Y-body, F-body LT4: 203/210 0.476/0.479 lift 115 LSA
Old Apr 4, 2013 | 05:43 AM
tonskiguy's Avatar
How about just swapping in some 1.6 rockers, that would be pretty mild.
Old Apr 4, 2013 | 05:55 AM
nascarnate326's Avatar
hotcam kit.
Its been proven my tons of people to be a decent choice. Comes with most of the parts you need. If RPM's are kept in stock range springs wont give you problems.
Old Apr 4, 2013 | 08:13 PM
cardo0's Avatar
Default 330hp would be very optimistic with LT1 heads.
Ah but the stock LT1 is only 275hp so 330hp is 55 more hp and would be a 20% pwr increase. Yes anyone would feel that difference. Not many "mild" cams can claim 55hp increase over stock. But lets be realistic with using LT1 heads instead of the LT4 heads the gain would be much less. And again the vlv springs would have to be changed for any real improvements. But i would take a 55hp increase anyday.
BTW i have to drive to Las Vegas now just to drag race since Cal Speedway closed. Its plenty fun to race there but my car is slow as heck in that 100*F heat and i always seem to break something at the track too. Wish i could make the Summit Nationals this weekend. Maybe see u there some time 96.
cardo0
Old Apr 4, 2013 | 09:49 PM
RamAir95TA's Avatar
Originally Posted by cardo0
Ah but the stock LT1 is only 275hp so 330hp is 55 more hp and would be a 20% pwr increase. Yes anyone would feel that difference. Not many "mild" cams can claim 55hp increase over stock. But lets be realistic with using LT1 heads instead of the LT4 heads the gain would be much less. And again the vlv springs would have to be changed for any real improvements. But i would take a 55hp increase anyday..
cardo0
Good lord you can't be serious.
Old Apr 5, 2013 | 07:47 AM
SwampWS6's Avatar
ok, well should i or shouldn't i buy the cc 503 cam? I understand changing the valve springs is something i should do as well. so the 503 cam or the LT4 cam? Let me know before i pull the trigger on buying these parts! Im enjoying the input, im learning a lot plus the research i am doing. . . . .
Old Apr 5, 2013 | 07:57 AM
That dependa on your goals with your car. The 503 will make more power and is gona wana be turned to around 6200. If your auto your gona need 3k stall and atleast 3.42 gears. The hot cam is would be a great cam for a dd. You could probly get away with stock stall and gears. Both cams gona need springs, 1.6rr, tune, hardend pushrods, new timing chain, and proper supporting mods.
Old Apr 5, 2013 | 08:07 AM
SwampWS6's Avatar
what's the best rockers and and springs to complement the cc 503 cam? Or should I just get the LT4 hot cam kit?
Old Apr 5, 2013 | 07:25 PM
Ed Wright's Avatar
9-Second Club
Properly tuned bone stock automatic trans F & Y body LT1s run quickest shifted at 6000, with the "hot" cam kit they run quickest shifted at 6500.
Old Apr 5, 2013 | 07:43 PM
myltwon's Avatar
Any quality 1.6 will do, crane has some nice ones, I run Scorpian aluminum 1.6 rr's though some will say they're no good I had zero issues. If you decide to run NSA as opposed to SA rockers you will need guide plates and hardened/chromemoly pushrods. As far as springs I ran the crane spring kit 10308-1 with my cc503 and have them on my current motor. Includes everything you need to install it without having to piece together your own. Though with a dual coil spring you will want to run smaller style valve seals since the mushroom style will have issues fitting IIRC.
Old Apr 6, 2013 | 05:15 AM
TA_Moscow's Avatar
Is cam install worth on stock engine? I mean without headers, cai, catback, etc bolt-ons. And if i put 1.6rr's do i have to change the valve springs too? i've also read, that i will have to change my value cover, is it right? And the most hard question for those living in East Europe and Russia- do i have to make the tune? Or i can buy the chip, i mean i'm not sure that i can properly tune it in Moscow.
