pro charger and compression ratio???
Old Apr 7, 2013 | 02:35 PM
lt1muscle's Avatar
Default pro charger and compression ratio???
ok guys I have a few questions about my build. my original plan was to build a high compression naturally aspirated motor, but im really leaning towards a procharger now. The thing is I already got all the machine work and reassembled my shortblock a few months ago. so my current set up is bored .040 over( making it a 358), align honed, full rotating assembly balanced, ARP main studs, block decked to .005,( I wanted to get it zero decked but my machine guy said it would be good to leave just a little to play with for insurance reason), new cam bearing and plugs, stock crank polished, eagle rods( SIR 5140), SRP pistons( 138082 forged flat top +5.00 cc), felpro head gasket(1074 .039 compress thickness). my original plan was to run a Le head with a 52 cc which would put me at 11.98 to 1 static compression ratio. Now if I keep everything the same but run the LE trickflow 23 degree which have a 62 cc I believe( correct me if im wrong) will put me at 10.55 t0 1 static compression ratio. the stock lt1 compression ratio is 10.5 to 1 so it seems like an alright compression ratio to run boost. It is not a daily driver just something I will take out on the weekend and the track a couple times a year. I just want to get your guys input and opinions because I really want to go the pro charger route. thanks! this is a pic of the shortblock I assembled back in december
Attached Thumbnails pro charger and compression ratio???-156129_10151592589044698_214357273_n.jpg
Old Apr 7, 2013 | 03:29 PM
F0x Slaughter's Avatar
With a good tune you could probably run like 12psi.
Old Apr 7, 2013 | 05:23 PM
lt1muscle's Avatar
so 10.55 to 1 compression will be fine with a procharger? I didnt know if the compression should be lower
Old Apr 7, 2013 | 05:40 PM
Depends on how much boost you want to run.
10.4:1 is stock and you can run 8psi for safety reasons.
Its not so much worry about the compression ratio either its more about the bottom end holding up to the punishment.
These are traditional SBC, where they came stock 9:1.
Old Apr 7, 2013 | 05:43 PM
BADMOON's Avatar
I have seen guys run more compression than you and 12 pounds on e85.. If you have e85 at a pump near you may be worth it.....
Old Apr 7, 2013 | 06:21 PM
BIGCAT7274's Avatar
open up your ring gap. have the cc opened up a bit.
Old Apr 7, 2013 | 08:06 PM
lt1muscle's Avatar
alright cool guys, thanks for the input!
Old Apr 8, 2013 | 06:10 AM
kgkern01's Avatar
This.
E85 can make tons of power safely with boost! It will allow you to run more compression, boost, and timing safely, which can net a LOT of power.
Old Apr 8, 2013 | 09:04 AM
lt1muscle's Avatar
Im kinda new to E85 but I know a pump near by I could use. what exactly do I need to run E85. new fuel pump, injectors, etc. ?
Old Apr 8, 2013 | 09:45 AM
kgkern01's Avatar
Injectors and fuel pump that can support at least 30% more fuel than you would need with gas, more frequent fuel filter changes or stainless filter,and a tune. That's mostly it.
Old Apr 8, 2013 | 10:33 AM
lt1muscle's Avatar
ok cool I am going to look into doing that and see if I have a E85 pump locally which im pretty sure I do.
Old Apr 8, 2013 | 07:58 PM
myltwon's Avatar
Another option is looking into meth which is more readily available and doesn't require change your fuel system. Not to mention it's only used when you need it as opposed to having to keep within range of an E85 pump.
E85 is great but it's not widely available enough, atleast where I'm at, to be considered a viable choice for a street car.
Old Apr 9, 2013 | 11:40 AM
lt1muscle's Avatar
fortunately for me I have 2 e85 pumps within 5 miles of my house. the car wont be a daily driver just something I take out on the weekends. I still need to do a little more research on e85 before i make my final decision.
