What do u think guys think it will run
Old May 22, 2013 | 06:10 AM
  #81
bufmatmuslepants's Avatar
Your compression should be around 12:1, my guess is the builder used stock thickness gaskets but there's only 1 way to find out, by pulling them. Going to an 0.026 gasket could bump you to around 11.8 which would be much better by keeping compression on a larger cam. Even your hotcam or custom LPE or whatever you have would greatly benefit from higher compression. With reverse flow cooling we can run up to around 13:1 with a good tune on 93 pump gas. Pcm4less will email you a tune if you buy an aldl cable and download the free software and load it yourself, and will give free retuned for 6 months I think if you don't change heads/cam anything major. Just get a wide band or strap it to a dyno with air/fuel measurement and send results to Brian and he will update your tune and send it back to you.
Old May 22, 2013 | 02:52 PM
  #82
See U Later 4's Avatar
Originally Posted by AChotrod
Thanks and its def a work in progress. But if your car isnt a DD this cam is great and should work great with a 4k Stall and the right supporting stuff(rockers injectors tune etc.). Ill practically give you the thing just to see what your car will do.
Im in Fox River Grove
THe car is not a dd at all i have a tune done by Ion you probally know him how much do u want for the cam
Old May 22, 2013 | 02:54 PM
  #83
Thanks for the info i will let you know when i get a chance to work on the car i don't know of you know him but the car was tuned by a guy here in illinios named Ion people say he is pretty good at what he does
Old May 22, 2013 | 06:39 PM
  #84
96capricemgr's Avatar
I would sooner suspect .039 Felpros than stock, and if the compression is that low with them you have less opportunity to improve it
Old May 22, 2013 | 07:11 PM
  #85
gjohnsonws6's Avatar
Nice to see this thread turned around for once. Does not happen all that often here. You could use a feeler gauge at the front of the block/head and measure the thickness. I don't remember all your specs but you could also use a light and mirror with a plug pulled and see if it at least has flat tops in it. Might be helpful in determining the cr.
Old May 22, 2013 | 07:13 PM
  #86
And if you do the cam swap you would have access to measure the thickness with the intake off
Old May 22, 2013 | 07:28 PM
  #87
ZzTeaRs's Avatar
lol wow this thread derailed quick as hell, but i would say 12.62 105
Old May 22, 2013 | 08:24 PM
  #88
I have to get the info u might be right i don't know the guy who built the car said alot of this and alot that but after we took the car we found several issues too many to list and i am just now getting some of them worked out with a small budget and two baby girls the car will always be a work in progress it runs strong right now for what it has but i want more i will take it to the track here in the next few weeks and post times and slips and possibly a video
Old May 22, 2013 | 08:32 PM
  #89
BADHAWK51's Avatar
Originally Posted by CamaroRacing12
I race for $$$ only. Pony up boys
How many you need ?
Old May 22, 2013 | 08:38 PM
  #90
Originally Posted by BADHAWK51
How many you need ?
Bad *** Car you have
Old May 22, 2013 | 08:42 PM
  #91
With the pressures and responsibilities of a family it is more important to get things right because mistakes can price you right out of the hobby.
I get the kids thing, two small ones here too. Hoping I can use little hands to reach bolts I can't in coming years.
Old May 22, 2013 | 09:00 PM
  #92
VAformula's Avatar
My dad did that to me when I was young.....
Made me a better man by learning a trade, but I never liked it as a kid.
Old May 22, 2013 | 10:35 PM
  #93
CamaroRacing12's Avatar
How many you need ?
Let me setup the two stage then we'll play
