reluctor fabrication
Old Jun 1, 2014 | 03:10 PM
  #101
WhistlingZ's Avatar
Back in 2011, Wicked94z modified my opti and put a cam sensor in it. I never opened it, but the pics he sent me shows a 4 tab wheel spinning under the rotor. The cam sensor connects to my gen7 Dfi. I run an msd crank trigger as well. Works perfectly.
Old Jun 2, 2014 | 10:17 PM
  #102
KLaBZ28's Avatar
^ thats the 4x setup which is pretty sweet alternative.
I will post in here with any updates. Haven't worked on this project much because of finishing school but all done now
Old Jun 8, 2014 | 04:42 PM
  #103
Tinbender59's Avatar
I have 1 4l60e to rebuild then Im back on the MagnaTronX, hope to be installing it in 2 weeks! sorry for the delays but life does happen.
Old Jun 8, 2014 | 09:05 PM
  #104
transbird95's Avatar
care to post pics if you have them?
Old Jun 11, 2014 | 02:14 AM
  #105
I to would be interested in how he did this
Old Jun 11, 2014 | 11:21 PM
  #106
4L60E is torn down, clean it up and back together soon!
Old Jun 12, 2014 | 07:40 PM
  #107
WhistlingZ's Avatar
Here's the only pic I could find of the inside. Hope this helps.
Old Jul 2, 2014 | 05:21 PM
  #108
yep I actually have those sensors, but the temp rating is way off. hum??? maybe I need to revisit that one??
Hay Guys, sorry for the long sabatical, have had some serious family issues, and they drove me to a couple of stress/anxiety attacks. I thought that the 2nd one was a full blown heart attack, actually don't know yet?? I had to deal with, and make arangements to get the situation some help. I hope to be back on this project real soon. I havent given up on it yet, so dont you guys give up either. I will do my best figure it out.
Old Jul 3, 2014 | 05:01 PM
  #109
I am actually thinking of stepping back, and using that sensor?? I have the capability of monitoring external temps with EFILive, and was thinking I'll put a "J" type thermocouple on the Opti housing to see what the actual temp gets to?? if it is below 250 should be ok?? and I do like that sensor better.
Old Jul 3, 2014 | 08:29 PM
  #110
this is the temp range of that sensor,
-20°C to +85°C (-4°F to +185°F)
It will be questionable at best. any thoughts on the temp of the Opti housing when running, and see if this sensor has a chance of surviving??
Old Aug 2, 2014 | 10:44 PM
  #111
Hay guys I'm getting my **** handed to me on this 4L60E, As soon as it is FINISHED I'll be back on this, I Promise!!!
P.S. the heart doc. gave me an all clear. Whew that Is a load off of my "chest" LOL!!
Old Aug 3, 2014 | 05:41 PM
  #112
ccreddell's Avatar
Lloyd, you need to change your sig to "Lunati's version of the LT4 hot cam"....
Old Aug 4, 2014 | 12:07 AM
  #113
oh Crabs ok
Old Aug 4, 2014 | 09:17 AM
  #114
nitrous2fast's Avatar
I'm sure there probably is a internal temp difference between the vented Opti and a non. The vented is sucking intake temperature air into it at all times.
Old Aug 5, 2014 | 06:07 PM
  #115
Exactly my thoughts!! use the vented and It should have a chance??
Old Aug 6, 2014 | 07:58 AM
  #116
There is only one way to find out!
Old Aug 6, 2014 | 07:14 PM
  #117
Today worked on the distributor, another couple of hours It will be ready to install. I have my cam, replacement Intake, Valve springs, 36lb injectors, Water pump extenders and drive, EFILive ready to start data loging. need to order Brass bolts to plug the Original LT manifold bolt holes. planning to start either, 8/11/14 or 8/18/14 depends on the 4L60E owners pockets
Old Sep 5, 2014 | 11:46 PM
  #118
Whipped383's Avatar
Well?
Old Sep 6, 2014 | 09:32 AM
  #119
superspirit's Avatar
Hey Tinman, time for an update.
Old Sep 15, 2014 | 11:02 PM
  #120
FINALY got rid ot the POS that was killing me, it had a broken reverse piston, a hairline crack. Son Of A Gun!!! 3 months 4 teardowns and $1000 to a "trans shop" to find it!!!!! but it is gone. will be on the LT1 project ASAP I promise!!
