reluctor fabrication
My other choice is to stuff the Vortec disttributor in the back of the intake and use it as the cam signal only, but I really would rather have a reluctor wheel made then try to stuff any type of distributor under the cowl of my Z. Anybody have any recommendations on who to get ahold of???
The only other way it gets easier is to do a full LS swap.
i had a control panel door laser cut through a shop we do a ton of work with and it cost 250 for him to wright the file and another 150 for the door to get cut out.
Hey been there lol. Now didnt we talk about a cam sensor but crank trigger style at one time? Is that still a possibility? Like maybe notching the balancer or the pulley and making it think its a cam signal?
tinbender
Ya I'm still working things over in the ol bean. Best with least crap involved
"Kevin Reed"
Do they make a cam trigger with 4x?
tinbender
Not that I'm aware of
"Kevin Reed
I meant 1x. Thats what we need right? 1x? Got the 4x crank right. Do u remember a link I sent a while back that had the optical sensor in the distributor? What u tgink about the other way around? A cam sensor in the opti spark! Theres got to be a way. That would eliminate a different intake and trying to squeeze a distributor back there.
tinbender
I do have an idea to mod the option to a 1X trigger. Have you got a dead opti that you could send me to play with??
Kevin Reed
I have a good one lol. But its a spare engine! What ya thinking? And I was going ro tey to get a cam sensor to tinker with. But if u got an idea. I was going to purchase a vortec dis to use the reluctor and sensor. U have more equipment to use than me lol.
im thinking this may be a direct swap. Check attached pictures. The cam sensor is held down with same size bolts look rhe same distance, and is a flat sensor. May need spacers under it or something. This looks semi easy. What ya think?
tinbender
Im not sure without them in my hands but that was my original thoughts, when I get it here I'll dig into it where there is a will there is a way lol. I haven't been able to contact lex yet. I think he is 2 or 3 hours ahead of me so he is probably asleep
Kevin Reed
I havent mailed that yet but I will later im at a buddys ges going to let me look at his 4.3 distributor which I assume are the same as 5.0 5.7 amd just see if that reluctor will pop out and if it looks like ittle be easy.
tinbender
Cool
Kevin Reed
H@!^C*@&. Called our tunimg place and they still want 300 for a tune and 125hr on the dyno. 425 seems like alot of money. Good Lord!!
tinbender
I would guess. Sheesh. If you were closer we could go together an buy an EFI LIVE for the price of both of our rigs. Lol
Kevin Reed
Alright I fabbed up some wonderful drawings lol. I sent u a video and pics. Let me describe.
The pictures, now I rotated the engine and scraped 2 markes on the metal housing and aluminum housing of opti. Now there are 2 marks cause I rotated the engine back and forth and thats the section that the piston didnt move. And youll see the sexond puc I circled 3 holes thats where they mount to block as im sure you know on yours.
Now the video if u watch how I turn it, one would think if you could widen these holes or even weld some sort of openimg for the bolts to move in you could loosen these 3 bolts, adjust the dizzy to get it started and tighten then adjust timing in pcm.
tinbender
I like it, that gives me a lot of information. Might not need to ask so many questions ltr.
I'll give it my best shot and I'll be discussing it as "we" go
Kevin Reed
Also sent u the harness that plugs in to the opti as it may work with the vortec plug. And also a question about the opti do u think doesnt it have the same low voltage that rhe vortec requies? Could you just not use the high voltage side and just fill in the windows on the disc or cut them out?
tinbender
The option runs on 5 vdc. And the 411 needs 12vdc inputs hence our problem
Kevin Reed
Ok I thought the opti ran a 12 and a 5
Tinbender
No it has only one input voltage
Kevin Reed
Ok I misunderstood. Im still figuring out how they work!
tinbender
I don't think that is right. At all. The 2 5vdc he is showing (I think) are outputs to the ECU. and the 12vdc should be 5vdc supply with d as ground. ??? I would have to look it up to be sure. The opti has 2 -5vdc optical readers hence the 2 sets of windows. And these outputs go to the ECU
"Kevin Reed
Youd know more than I lol. I just kept reading about high and low voltage eve...
tinbender
I may be all wet??? I did run from the opti-no-spark. Lol
Kevin Reed
You did lol. Its funny I typed in vortec reluctor in optispark and here’s what I found on google ... your truck lol. Every time I start a google search about this your on google images
tinbender
I'm famous. !!!
lOl
Kevin Reed
You know I just thought of it but I got a guy that o wemt to school with right down the rd that could help with machining if you think of anything. I could probably get him to copy efi connections kit lol. I mean or even mock up a setup like it.
I was even thing hell cut a portion of the dist rod off and weld it to the portion of the opti thats there when u take the rotor and optical disc out. I may go this route. 40 for a used distr or 50 for new then 30-40 for a used opti. Cut the shaft add the sensor in opti and boom u got a 100$ sensor. Beats the 800 from efi
tinbender
Now you are thinking like me. ;-)
Kevin Reed
I may go ahead and purchase a 5.7 dis. Is the 4.3 dist have the same internals? My Buddy has one.
https://ls1tech.com/forums/lt1-lt4-m...brication.html
tinbender
I believe so just smaller
Kevin Reed
Sensors are the same. I would assume the reluctor would be the same 1x signal?
Tinbender
Yes I believe so
Kevin Reed
Well I did find that the shaft on the 4.3 is balanced. So ill scratch that and play it safe. How will the one we get on the opti get balanced?
tinbender
??? Never heard of such a thing.
Kevin Reed
Would it need to be? I mean its a ring with uneven cuts and holes lol. Think it will wobble at 3k rpms and fall off lol
tinbender
I wasn't worried the ring should be balanced already. And we are just moving it ???
Kevin Reed
I guess your right there. So I guess welding it to another shaft wouldn’t matter.
tinbender
I don't think so. ???
Kevin Reed
Your adding question marks making me think u really dont know hhaha. Kidding. I found a few more threads u may be interested in. Seems like more people are intested in doing this in I thought. Sounds perfect though. No dropping engine for distributor, plug wires and all in same location.
Do you think its possible to convert this single coil setup to coil over plug?
tinbender
Only with 24X. Or 52X not the 4X. Been down that road already. Sorry. What site are you seeing the interest?
Kevin Reed
I sent u one a few emails back. They even mentioned u lol. I just googled vortec cam sensor in opti and found a few mentioned it but no replies. You’d be surprised
Wow that took some work :-)
I still really enjoy seeing updates on this stuff and glad to see people still pioneering parts and making things work. How are you liking that TPI intake on your LT1? I have always thought the Tuned port 350 was about the best truck engine that chevy made.....and then never put into a truck.
i'm interisted in a time slip from a car with this setup oh a really nasty idea is forming in my lil bean Cheap M90 SBC manifold!!! muh ha ha ha
