reluctor fabrication
Old Mar 29, 2014 | 01:54 PM
  #81
KLaBZ28's Avatar
I've been working on designing my own reluctors myself, there is a lot of work involved to make the correct signal and have it balanced for vibrational noise. This R&D is what makes the EFI Connection the price is it. You are paying for the design, not a chunk of metal.
I'm interested to see how your version works.
Old Mar 30, 2014 | 04:43 PM
  #82
Tinbender59's Avatar
You are making it harder than I needs to be. My biggest hurtle is the sensor and how to interface it.
Old Apr 2, 2014 | 08:32 PM
  #83
I am pumped today!!! I had to hand mill the Opti housing, but it is assembled, need to do a little final tuning, but mechanicly it works!!! spins free with good clearence, waiting on the electronics components so that I can let the smoke out of them (burn them up) lol. once the electronics are ~working~ ? I will get it on the truck for testing. I am going to be going back to the dyno for a retune, so I will wait until this is on the truck and proven to run, then test it on the dyno as well. Isn't it cool how God works things out??
how does Magna-TronX sound???
heads up guys n gals, when I get this going and proven, I am going to build 20 units initially and would like firm orders with a small deposit, i am planning to make this a package deal on the first 20, after that I'm not sure on the availability of the 411's. the package deal should be A 411 if needed ( reduced cost if you have one already or I cant source them), my Magna-Tronix distributor with a modded pigtail - (plug right into your existing opti wiring harnes), repining spread sheet for the 411, a sealed amplifier to mount on the fender or?? close to the ECU with wiring instructions. the 411 will not have a tune for your setup. I am hopping that the high voltage section will be viable item so that you don't have to go to CNP unless you wish.
Old Apr 10, 2014 | 07:47 PM
  #84
picked up the rest of the needed tronix parts, now to get it all assembled and get the Water pump spacers to install.
Old Apr 14, 2014 | 04:01 PM
  #85
TSAEB's Avatar
Great read !!! I am to just waiting to see since I decided to do the 411/dizzy swap after all .
Old Apr 17, 2014 | 08:28 PM
  #86
I have the amplifier built, MagnaTronX built, now to get it installed, hope to get it done by the end of the month.
Old Apr 18, 2014 | 11:45 PM
  #87
Hay guys I've been doing some forward thinking. to come up with a fair price, I need input on something. Do I include a cap and rotor?? If I do, I have a personel conviction; If I wont use, it I wont sell it. in otherwords I will only include top quality parts, and they are not cheap $$$. Delphi, AC Delco, Bosh, .... when I get to the point that I have a large numbers of orders I should be able to lean on the supplier for better prices?? INPUT PLEASE!!!
Old Apr 19, 2014 | 10:40 AM
  #88
nitrous2fast's Avatar
You should give the option of a cap and rotor at an additional cost. Some people might have an almost new set and would not need them or the extra cost.
Old Apr 19, 2014 | 12:11 PM
  #89
superspirit's Avatar
^^^this^^^
Old Apr 21, 2014 | 09:35 PM
  #90
DONE!!!! also a quick note, I found my test lab from Tech school, and It still works, has 5 / 12 vdc outputs, a signal generator, and LED's for indicators!! I'll be able to simulate a running motor to test the amplifier, and test the New sensor in my MagnaTronX distributor, before It goes in the truck. Which will be nice to know that It does work on the benchso tha I have a known good setup, and if there are problems, the modded system is ruled out
Old Apr 22, 2014 | 10:10 PM
  #91
today I fired up the test lab, and .... the amplifier works like a champ, but the sensor in the distributor is not working, may be me???? maybe that the test lab puts out only 500mili amps of power??? or I havent figured out how to connect it up yet?? but at least I can test it befor It is in the hole!!! to find this out now. stay tuned, I have not said "die" yet!!!!
Old Apr 24, 2014 | 09:24 PM
  #92
Whipped383's Avatar
How fast are you spinning the dizzy? On the vortec the cmp doesn't read below 1000 rpm. I don't know why it is that way but its just a thought
Old Apr 25, 2014 | 03:46 PM
  #93
you are a friggin Genius dude!!! drill time!!!!
Old Apr 29, 2014 | 09:49 PM
  #94
Whipped383's Avatar
Well did it work?
Old May 6, 2014 | 10:13 AM
  #95
hay guy's sorry about the long time no post, this is a busy month, weddings, graduations ..bla bla bla.. I will be back on this soon!!!! please be patient tinman
Old May 6, 2014 | 06:14 PM
  #96
duh's Avatar
duh
Still can't wait! I just tore into the spare shortblock to start the 383 build. Hopefully I can get the engine together quick enough to try this. It could prove to be very fun! Keep up the hard work!
Old May 8, 2014 | 06:13 PM
  #97
Today, trying to make progress, so I was looking up the wires that I needed to "interrupt" to switch between the two distributors; Vortec / MagnaTronX. Could not find the supply voltage coming out of the ECU; (blind) or Divine intervention? Anyway ended up looking at the 2002 van schematics, and to my surprise, it had the internal drawing of the cam sensor with values on the resistors??? That is crazy!!! I’ll do the math, and verify it on the 411 inputs on my truck –but I think that the cam signal “IS” a 5vdc input. If you remember my replacement sensor is 5vdc as well?? . my mind is always churning out theories, Ideas, and data that I have to investigate, when I’m on a project. The LT install took 3 motors and a year total to get worked out to where it is now. I’m kind of **** about getting it right and don’t like to say quit!!
Old May 14, 2014 | 07:17 PM
  #98
hay all, today I ordered my EFI Live, and WB O2 sensor, will order valve springs soon, then should be able to rip the motor down, and set it up for testing. hopefully?? in 2 weeks. my next weekend off!! I am looking forward to proving my theories. or my insanity lol
Old May 27, 2014 | 04:45 PM
  #99
KLaBZ28's Avatar
How so? You need to make a reluctor that fits on the LT1 hub, has the correct offset to the crank sensor, and also the correct diameter to get the proper sensor to reluctor clearance, which you would then have to change the width of the teeth. If its the same diameter and as easy as copying the tooth pattern and offsetting it to the LT1 crank sensor location, then that's awesome. I don't think that's the case.
Old May 30, 2014 | 06:19 PM
  #100
Kevin Reed's Avatar
I thought of something like this to but my idea was either weld a BBC crank 24x reluctor from the 1999 to 2000 model yr which has a slightly bigger shaft, to the factory lt1 reluctor. A problem with this is finding the tdc before welding. The other idea was maybe machine a shaft to slide in the BBC reluctor which fits the lt1 crank.
After all my searching I ended up finding out this was EFIs original idea with the shaft for BBC reluctor.
I also found a guy that did this to but he had to cut and weld add spacer to the factory lt1 timing cover.
If your like me you have limited supplies and mostly hand and air tools but no way to weld aluminum or machine anything.
If you do find something that works for you please share. These ideas are interesting.
