how do Make my 94 into a 96 obd 2 connector?
Old 05-22-2013, 09:42 PM
SPOOLED UP's Avatar
Default how do Make my 94 into a 96 obd 2 connector?
I have the obd 2 connector but whats needed and how to wire this up so it reads as a obd2 connector?
writeup and pics suggested.
thanks
Old 05-22-2013, 09:51 PM
shbox's Avatar
Please clarify your purpose. There are DLC wiring diagram on my website.
Old 05-22-2013, 10:41 PM
SPOOLED UP's Avatar
putting in a ls1.
Old 05-23-2013, 07:16 AM
S10Wildside's Avatar
You'll need the OBD-II connector (or pigtail).
You'll have to:
  • add a fused 12V battery wire to pin 16
  • add ground to pins 4 and 5
  • run the serial data wire from pin 2 to the PCM (BLUE connector, pin 58)
You wont' be able to "make a 94 OBD-I connector into a 96 OBD-II connector".
Old 05-23-2013, 07:16 PM
SPOOLED UP's Avatar
thanks
Old 06-05-2013, 08:43 PM
Benlugchev's Avatar
You'll have to:
So what i gather from this, is that to feed information from computer to the OBD 2 port, I only need one wire (serial wire) coming from the computer to the OBD port. Im looking to do some logging with efi live which plugs into the obd.
Wow that alot easier than I had planned. Thanks for sharing
Old 06-15-2013, 03:12 PM
SPOOLED UP's Avatar
You'll have to:
OK, so I ran all of these wires to the obd2 port connector like you said. But what do I do with the original harness obd1 wiring? DO I use that at all or just omit it from the obd1 connector?
Old 06-18-2013, 11:53 AM
robsquikz28's Avatar
Last I remember is that u don't even need to use the obd1 wires if u make your own. Just tuck the obd1 connector away.
Old 06-18-2013, 09:29 PM
SPOOLED UP's Avatar
Thats what I was going to do and see what happens after.
Quick Reply: how do Make my 94 into a 96 obd 2 connector?
