White smoke on WOT...PCV issue?
My question: is the stock PCV system causing this? If so, what do I need to do? Install a catch can? Valve cover breather? Any recommendations?
Sorry for the bad news but sounds like head gasket. White smoke through the shifter means its leaking out the side of head/block too. My original engine had low compression in #8 and green gooie sealer oozed out between head and block. Maybe try some coolant sealer. Heck NASCAR uses it as they can't afford to trace down pin hole leaks during a race.
Hope this helps more than it hurts,
cardo
It turns out the white smoke had nothing to do with engine oil or water vapor from a blown head gasket (thank god..lol). Either I've been too rough manhandling the shifter or the guy that rebuilt my trans overtightened the shifter plate bolts and they were stripped....so at very high (6000+ RPM) when I'm banging gears trans fluid was spraying from the back of the shifter all over the exhaust creating the smoke as well as the puffs of smoke coming from the shifter boot, the carpet around the shifter was all oily and nasty from trans fluid. Luckily my local trusty former Pontiac dealership found the root of the issue during my state inspection and fixed it with Helicoils; they failed me for my slick Sumitomos though
Perfect excuse to buy some new, Toyo Proxes TQ drag radials now
Next thread, busted 10 bolt LMAO
People can add this to their "white smoke" considerations, as well.
