gm847
Stock crank and rods, SRP pistons, .043", .043", 3/16" low tension rings, block machined by the guy that did my race engine machining for about ever, Carroll Caudle at Carroll's Engine & Machine in Amarillo, TX. Honing is a big deal.
The guy that bought it from me put that cam, a set of Lloyd Elliot heads on it, 30lb red top Ford injectors and 1 3/4" Hooker long tubes. It had 4.10 gears and a manual Trans. No magic. Proper machine work, correct pistons & rings, nothing trick. Hp peaked about 6600.
But I will say my "always heard" comment was more from people I've known having experience with this cam, than something I "read on the internet". But since it wasn't my own personal experience, I'll defer to those who know more!
Needless to say my Hotcammed car gets wayy better times than him and I'm also in a stick.
), PCM, and k-member. I'm figuring I'll go with a tubular k-member to make the piping easier to mount. Yeah, buying the whole kit makes things a lot simpler. I ended up going with just the cam (the heads I got already had good springs). Thing I love about the hotcam for the street is how quickly it makes power (at least to me it does). If I'm not careful I'll blow my 315's away at 40 mph! Definitely a bitchin street cam!
I have a powerstick chambered muffler dumped at rear axel. It has a super tame idle compared to the bigger cams.
I usually shift at 6400 rpms at the track, I can take it to 6500 but I feel there isnt much of a gain.
The funny thing is my car isnt even dyno tuned. Still on the PCMforless mail in order. My best pass so far is 12.4 @ 113 on a 1.9 sixty. ( mickey thompson et street radials ) on a stick shift car. Im willing to bet once I put a bias ply drag tire and get a 1.7- 1.6 sixty I will have an 11.9x pass.
Unfortunately, people get caught up with the notion that 'a bigger cam is a better cam'.....and that just ain't true. There are a number of factors that will make running a big cam as being the thing to do......while those same factors (with different specs) could make a smaller cam a better option.
Once you get to the point where you understand the science of the internal combustion engine, you can understand how/why a moderately sized Hot cam can out-perform the big, burley 847 cam when they both are run in the same engine where the only thing changed were the cams and maybe the tune.
KW
I think my engine was turned to 7 quite a few times by the previous owner, and it's still running plenty strong in my car. I'd feel comfortable getting close to that on occasion if I had a cam that made power up there. I know I pegged the tach a couple times on accident downshifting before I pulled the rev limiter back and haven't had any issues.
