Air pump problem
Old Dec 19, 2013 | 09:08 AM
rjc1629's Avatar
Default Air pump problem
I was getting a check engine light for code P0410 (secondary air injection system). So I replaced the air pump, bleed valve and both check valves with brand new GM parts, but I'm still getting the code. I checked all the relays and fuses and they are all good. Any ideas?
Old Dec 19, 2013 | 10:34 AM
SS RRR's Avatar
Village Troll
is the pump engaging?
Old Dec 19, 2013 | 10:35 AM
rjc1629's Avatar
I'm pretty sure I hear it kicking on. From the research I have done that code means the pump is being cycled on but the O2's do not read lean like they should.
Old Dec 19, 2013 | 10:42 AM
SS RRR's Avatar
Village Troll
Make sure your check valves are good.
Old Dec 19, 2013 | 10:50 AM
rjc1629's Avatar
I replaced them with brand new GM check valves.
Old Dec 19, 2013 | 11:26 AM
SS RRR's Avatar
Village Troll
Take the hose off from the pump that is injecting air into the exhaust and see if you feel any sort of flow. Naturally, the only time to do this is when the engine is cold and in the operating window of the AIR pump.
Old Dec 19, 2013 | 08:40 PM
rjc1629's Avatar
I pulled the hose off the check valves and there is barely any air coming out. I pulled the suction hose off the intake and it had decent suction. So it seems like the pump is sucking air, just not pushing it out for some reason.
Old Dec 20, 2013 | 08:46 AM
SS RRR's Avatar
Village Troll
Maybe a bad pump then?
Old Dec 20, 2013 | 08:47 AM
rjc1629's Avatar
I guess it could be. I got it with the car but it was new in the box.
Old Dec 20, 2013 | 09:39 AM
SS RRR's Avatar
Village Troll
Did you check the voltage at the connection to the pump? Again, unless you can jump it, it'd have to be done in the pump's operating temp window.
Old Dec 20, 2013 | 09:42 AM
rjc1629's Avatar
No I haven't checked that. Would I check it from the wires between the plug and the pump?
Old Dec 20, 2013 | 12:54 PM
SS RRR's Avatar
Village Troll
You should be able to check it at the connector. Shoebox may have the schematics needed to see where the +12 is.
www.shbox.com
If not, a Haynes manual should have it.
Old Dec 20, 2013 | 01:03 PM
rjc1629's Avatar
Ok, thanks. I 'll check it saturday.
Old Dec 20, 2013 | 02:16 PM
devildog214's Avatar
just had that code, it was a fuse thankfully. Obviously if the pump is on then its not a fuse, but they do make a distinct sound almost like a turbo whistle or a kazoo lol.
