01-02 Express Van PCM in a 94 Camaro
Old 01-04-2014, 09:41 PM
96capricemgr's Avatar
I am very happy with Edge myself, but at the same time I believe in working through problems, it can be hard to figure out what was going on when you change direction too often.
Old 01-06-2014, 02:57 PM
NewOrleansLT1's Avatar
Ok so I got the 96' PCM and the odb2 ALDL pig tail. I know I have to get a odb2 knock sensor, but what do I have to do in order for the ALDL to function properly? Ed? Shbox? Anyone?
Old 01-06-2014, 04:21 PM
Where is the class 2 data wire located and how does it look?
**Edit** I found it. It's in the Blue connector on the PCM PIN number 7...
Old 01-06-2014, 07:29 PM
9-Second Club
Ed Wright's Avatar
My '96 factory shop manual is loaned out. Have a call into him, no response yet. Glad you found it. My '95 test mule had that wire from the PCM, to the connector inside the car. Just not the inside harness. I'm guessing the '94 may not have it. If you have something you have stopped using (AIR or EGR?) you could maybe rob that wire, move it to the needed position in the PCM connector to run it inside.
Old 01-06-2014, 11:29 PM
the '94 doesn't have the wire.. But thanks for the idea though.. I'm finally gonna kiss stall wall goodbye and use any scanner I choose..
Quick Reply: 01-02 Express Van PCM in a 94 Camaro
