Stock heads and intake
Can someone please give me some info on the stock 96 lt1 heads?Good or bad?
Porting and polishing??
Also give me the same info on the intake manifold??
Throttle body?? Better to change it out for a little bigger? 58mm??
Thanks in advance
Sorry for all the posts but i am just getting started on this project and i am trying to learn as much as possible before i make any set in stone plans. Better to do it once than have to put money into something that isnt worth it.
Far as the intake there isn't a lot to be had in porting it but is a decent idea to have THE HEAD PORTER port it at the same time you have the heads done. I would expect your car to likely have the 138 casting intake which has smaller ports that more closely match the heads as cast than the earlier intakes which actually had larger ports than the heads. That doesn't matter atall for porting.
Far as the throttle body, lots of debate on that, if you are aiming for a modest goal though I would suggest a rebored stocker to 52-54mm and avoid the headaches that come with the aftermarket units unless you can buy a used aftermarket that someone already modded to work right.
I was told by 96capricemanager when I joined the forum that 58mm will yield you nothing unless you have a list of other parts to make you need a larger TB(true)......
Thanks in advance
Your heads have 561's, which are better stock than the older heads, so your best bet if you are budget restrained is to get a cam that will utilize those heads.
If you want more power then get your hands on the older heads that I posted above. Along with a bigger TB and a ported intake to match.
But like I said, it all depends on how much you want to spend cause it really does snowball.
As a lot of us have said a lot of times, all the aftermarket TBs come with some sort of hassles.
Far as the 561s it has long been considered "common knowledge" that they were better but then some of the stock eliminator guys began trying to correct that myth, the stock eliminator guys can not do any porting and found those to be the slowest heads. GIZMO in particular has posted on this. Even said he believed he maybe just got a bad set and tried a couple more sets.
If u want advice on your build u really need to post power goals and most of all your budget. For example getting to 400hp is as simple as a cam and vlv spring change. Going to 500hp will cost 5 times to 10 times that.
Lets hear what u got and what u want,
cardo
Take it for what its worth but at my power level I did indeed flow more air with a 58mm TB
Unless you plan on having well ported heads and a cam to take advantage of them I would leave the stock TB alone
What a big help,
cardo
Got the OP worried asking: Everything OK at home?
No oversight on this forum here, so the saga continues,
cardo
Here is his reply.
Thanks again
Chris
cardo
