Axle hop, etc.
Old Jan 31, 2014 | 10:19 AM
HellTeeOne's Avatar
Default Axle hop, etc.
I know this has probably been beat to death, but here goes.
1997 Z28 M6, makes a little over 400rwhp NA. Stock 3.42 gear. 17" SS wheels with 275 section street tires. Suspension is completely stock other than a set of BMR tubular LCAs I installed years ago.
When it's anything under 65-70 degrees outside, I can't go full throttle until third gear without blowing the tires away, and sometimes it even wants to try and break loose in third. When the tires do finally try and hook somewhat, I basically get axle hop at highway speeds and have to back out of it entirely.
Would a set of LCA relo brackets and SFCs cure this hopping nonsense and maybe help the 7.5 rear live for a little while?
Old Jan 31, 2014 | 10:57 AM
DANOZ28's Avatar
all i know is i had wheel hop and by adding bmr LCA's, sfc, panh its gone. some would add torque arm to the list. i know nothing about relocation brackets. goodluck. ps if funds are tight first try welded sfc.
Old Jan 31, 2014 | 11:37 AM
SS RRR's Avatar
Village Troll
Relocation brackets should definitely help. More so than a torque arm. Use weld-on's. Make sure rear is square before welding. As it is the stock position for LCA's are barely angled enough to control anything. What brand of tires are you using?
Old Jan 31, 2014 | 11:41 AM
sweetbmxrider's Avatar
Get some mickeys
Old Jan 31, 2014 | 12:08 PM
Ed Wright's Avatar
9-Second Club
Why do you suppose the NHRA Stockers don't use them?
Old Jan 31, 2014 | 12:49 PM
SS RRR's Avatar
Village Troll
Use what? Relocation brackets? Do they also roll on a 275/40/17 tire?
Old Jan 31, 2014 | 01:10 PM
Shownomercy's Avatar
Man-Crush Warning
Tall *** 30" tires perhaps?
Old Jan 31, 2014 | 01:21 PM
Ed Wright's Avatar
9-Second Club
He needs shocks.
There is an awful lot of fast cars out there without them, that do not wheel hop. Mine never did on short tires.
Old Jan 31, 2014 | 03:48 PM
smitty2919's Avatar
60K mi, boxed in stock rear LCA's, stock springs/shocks, welded relocation brackets but in middle hole, adjustable PHB, NITTO NT555's and it's spin city for me.
I haven't had the car in warm weather yet, but so far this winter all I do is spin with no hop.
Old Jan 31, 2014 | 04:59 PM
nitrous2fast's Avatar
wheel hop comes from the axle's energy not being controlled. there are many reasons that it isn't being controlled. No LCA relos aren't really the Best answer. The stock torque arm flexes a LOT and that can mess with the tires ability to handle the load after the initial flex. Also the Pinion angle stock is always closer to zero to decrease wear and losses of energy through the driveline. This at zero and a Flexible TA can actually make the axle not put enough initial forward energy that stays forward. The TA flexes back down actually pulling the body of the car backward causing a loss of weight on the rear tires causing them to lose grip and spin, then it starts all over again. Also the shock controls the weight transfer of the car to the tires. How fast and how strong. Bad shocks are terrible for allowing wheel hop. The bad shock allows all of the weight to transfer but doesn't work well enough to keep the axle from moving to fast up and down to keep the weight there. Its mostly about smooth controlled weight transfer. A few other things but that would take an entire book. lol
Old Jan 31, 2014 | 07:25 PM
Ed Wright's Avatar
9-Second Club
Basically, his shocks are way too soft, especially on compression.
Old Jan 31, 2014 | 07:33 PM
bowtienut's Avatar
Ed and nitrous2 are right on. worn out shocks and anything flexible in the system are the contributors to your wheel hop. Stock bushings are marginal when new; those in your "completely stock other than..." suspension should be replaced. With all that working against you, relocation brackets can actually make the problem worse - hitting it harder makes it bounce back harder.
Tire height has very little to do with it.
Old Jan 31, 2014 | 08:28 PM
Man-Crush Warning
So same suspension setup, one with a 26 inch tire and 17 inch rim, the other a 26/28 inch tire on a 15 inch rim would launch exactly the same?
Old Jan 31, 2014 | 10:02 PM
bowtienut's Avatar
I don't know where you're going with that one. Of course they won't launch the same; not if you're hitting the tires with anything. But they may "wheel hop" the same
By tire height I was referring to the comment about 30" tires, not sidewall height.
Old Jan 31, 2014 | 10:42 PM
Man-Crush Warning
I was just going down the road of people who are used to a large sidewall/small wheel will have less pronounce symptoms of wheel hop and would be quick to disregard LCA relo brackets cause they don't need them.
Whereas a small sidewall,street car will probably feel that wheel hop a whole lot more.
All I was getting at.
Old Feb 1, 2014 | 08:12 AM
Ed Wright's Avatar
9-Second Club
Those. "LCA brackets" aren't needed. Decent shocks & bushings are. Worn out cars wheel hop.
Old Feb 1, 2014 | 08:48 AM
Man-Crush Warning
Funny then, that almost all of the big three of aftermarket rear end companies offer a welded in LCA bracket to adjust LCA angle.
Old Feb 1, 2014 | 09:35 AM
guppymech's Avatar
On my car having the relocation brackets and being able to lower the aft end of the lca definitely plants the tires better reducing how long the tires spin and eliminating the wheel hop I previously had.
Old Feb 1, 2014 | 09:57 AM
Adam1203's Avatar
Don't two of those companies require them to install the axles because of the design? I could be wrong about it because its been a while since I read anything on them and just might be confused.
Not saying they do or dont help I have no experience with them.
Old Feb 1, 2014 | 10:31 AM
jrwilliams95z28's Avatar
shocks help but as people said, LCA, PHR, TRQ arm and shocks all work together to keep the rear planted
