Simple bolt ons worth it?
60K miles
Custom CAI
Pacesetter L/T's...no EGR or Air pump
Catless midpipe
Borla 3" Catback with Hooker Maxflow muffler
Dyno Tune
Tuner and anyone I mention these numbers to say that is pretty strong for a "stock" LT1. I am by no means a "number chaser" but if I can get some more out of the car in a simple manner I would be interested to do so.
I was contemplating picking up a 58mm TB, try doing a slight porting job on a stock intake, converting to a LS1 SLP lid style intake, crank U/D pulley and go in for a retune.
So cost invested I see as:
Stock intake "free" - I have a buddy that will give me a stock intake to port/use then I give him my stock one back.
SLP lid - $75-ish if new, can save if buying used.
58mm TB - $? undecided what one to go with
U/D pulley - $?
Retune - $125/hr on the dyno
Any opinions on how much these cars pick up with those mods? What TB are you running that is not giving you issues?
Thanks Guys.
Dean
60K miles
Custom CAI
Catless midpipe
Dyno Tune
U/D pulley - $?
Thanks Guys.
Dean
Don't waste your money on a 58mm TB. You aren't making enough power to warrant any gains. I would just have the stock one ported.
I think UD pulleys are a waste of money
I'd like to see pics of your air intake setup, I doubt you'll see much gain going to a LS lid setup.
Porting your stock intake isn't a waste, it probably won't gain a whole lot but it will be ready for if you ever do H/C.
Porting the intake is worth nothing at this point. Don't bother to pull it off. I'm running an unported one making about 540 crank hp.
Aggred, the best TB option is a stock one re-bored to 52mm. The openings at the front of your manifold will accomodate that.
U/D pulley is worth 5 hp at most.
You need to run that car down the track.
I have no interest in 1/4 mile times...building the car for AutoX and RR. But I keep reading how well these motors respond to simple mode, so I figured I would make the best out of simple bolt ons and leave the motor untouched.
lt1-xjs: I forgot about RR's and springs. the tuner also recommended 1.6's for a simple easy swap to gain some power. I always heard that but forgot about it lol.
For now the WP will stay stock unless it starts giving me problems.
Here is the CAI I made. I may go to the LS1 lid due to the fact that my MAP dropped down to 92 at it's lowest point through the pull when the tuner said a Moroso CAI will keep steady at about 95KPa. I took a K&N CAI off to go with my custom setup. I have no dyno numbers or MAP readings from the K&N unfortunately so I don't know if my CAI is better/worse/same as the K&N.
It is a 3.5" pipe slightly dimpled at the bend to clear the stock 95 hood. It's the first version of it so it's not "pretty". basically did it because I can and wanted to try something different.
And now that I think of it...anyone think all the aftermarket 3.5" catbacks are a little small? Last time I built a catback for my 04 GTO I went with a single 3.5" to mimic a 2.5" dual setup from a cross sectional area standpoint.
On the flipside, I guess the only way to tell if the dip to 92KPa MAP reading is from the intake side of things and not the small exhaust side of things is to do a pull with only the MAF on the TB...
It is not a max effort build. As far as I'm concerned where it is now is prob more car than I can handle for autoX needs.
It would be nice to eventually get back to power level of my 04 GTO at 340/356 with a CAI, full exhaust and a tune.
I'll look into porting the stock TB though as well as maybe cleaning up a stock intake and tossing on a SLP lid.
1.6RR/springs, trickflow chromemoly pushrods, and EWP would be a good direction to head.
I dont know if you will gain much with the LS1 lid over the style of intake you have now, ls1 vs stock is an advantage in the higher rpms though, I am sure yours is aswell.
Who makes a reliable RR/spring setup?
bufmatmuslepants why do you said a EWP does not belong on a road race car? (I won't be road racing for a while due to no car trailer and $$ to sign up for one of those events but anywho...)
The electrics free up power by DOING LESS WORK. How much time does an engine spend below 3000rpm making power that really needs cooling?
The electrics are ADEQUATE for most street and drag cooling, but they are a downgrade it true cooling capacity.
On the NSA rocker topic, standard guideplates don't fit LT1 heads perfectly, a couple of my rockers are not perfectly centered, you need adjustable guideplates from isky or trickflow or another. Doing rockers and a good spring now that will work with a future cam upgrade is a way to do things in steps, rather than dropping $1000 all at once on a cam swap. I got my pro mags, Howard's springs (good if I went as big as a 503 but not going to work on the .600/602 lift cam I ended up buying), pushrods, guideplates and 7/16 studs for $300 by shopping around used parts.
And thanks for the heads up about the RR. I may start searching around for prices etc and see what I can come up with.
The C5 wagon wheel, while not the prettiest wheel, will be good to serve a purpose lol. I have chrome (but crappy chrome) staggered 17" ZR1 wheels now. I would rather a square setup to be able to rotate wheels (reliability purpose again).
Oh yes, do not shop for rockers by price! I tried that a long time ago and it didn't end well! "You get what you pay for" rings very true here, get the best ones (or maybe one step down) that either Comp cams, Lunati, or Crane cams sells. I like a company that stands by it's product for LIFE!
Here is the dyno sheet from the other day:
I may not mod ANYTHING this season as far as suspension goes. With the exception of LS1 front brake swap that I will be doing this weekend. I would like to approach autoX in a systematic manner. As I get to be a better driver and "out drive" the car, then I will want to mod.
I wanted to bring this up since it was fresh in my mind from the dyno and to start planning future mods.
Honestly, first step would be to dump this staggered ZR1 wheel setup. It's proving harder than I thought to find a simple 17x9.5 wheel all around. Vette wheels always seem 17/18 staggered. I've looked into the "wagon wheels" and even "sawblades" LOL. It won't be a fashion show with the car. It needs to be effective and sawblades are cheap allowing me to run a 275/40/17 tire.
As for your dyno sheet, where you see it to drop off at 5500 is where your valvetrain is holding you back. Springs and rockers will take it farther to 6000.
