LT1 smoking like crazy
My vote goes to double stacking oil filter o-rings, thus oil is leaking from the filter onto the exhaust
ding ding ding how much do i win?
edit: (more info) Sometimes when you remove the filter the o-ring from the old filter will stick to the oil filter adapter so when you install the new filter you double stack the o-rings and you will never have a oil-tight seal. When oil leaks from this location the chances of it hitting the exhaust and causing your cloud of smoke is high, along with it being swept back and covering the back of your car.
Thats about the only thing I can think of that could cause your issues immediately after changing your oil
You will read high before the oil filter gets filled, if you have the short filter it holds about a half a quart, if you have the tall filter it could hold 3/4 quart
if I remember correctly with my stock pan and a long filter I would add about 5.5 quarts and after starting it and filling the filter I would end up right at full
Sounds like if it just happened after the oil change then its something to do with the oil change lol. If it is sitting still and you rev it does smoke come out of the exhaust pipes? Does it come out of the engine bay? does it just leave a puddle on the ground?
We need to know where the smoke is coming from, it sounds like its coming from the engine and burning on the exhaust. The intake gasket leak could have gotten larger and is now dripping onto your exhaust. The fact your car is coated means its probably not piston rings, that smoke should only come out of your tail pipes.
I would check the filter for a double gasket or its just leaking. Drain plug could be leaking. This shouldnt be that hard to diagnose.
Were your valve covers ever off?
Perfect excuse for a T56 conversion! Manuals are just cooler! (Significantly more rare (3 autos built for every 6spd), and might actually add value to the car, I know the factory 6spds pull a good premium price over autos and the market is slowly getting better as these car's value has pretty much bottomed out and supply is slowing shrinking daily.
Rated for 450lb/ft stock, super tall .50 6th gear for running 4.10's, closer non-OD ratios 1-4, makes car autocross/road course not pointless, manlier, 10X more fun, takes much more skill and practice to be good at (can be good or bad for you
^What's not to love?
I'm fully aware I'm fighting a losing battle here, SAVE THE MANUALS! Few appreciates the link between man and machine that only comes with driving a manual transmission as the take rate on them is only 7.2% of the US auto market last year
Meanwhile, on the other side of the pond, 80% of mainly girly European cars sport a manual; while they chuckle away at our laziness/unwillingness to change gears for ourselves. Everyone on here needs to go buy a new manual trans car ASAP, or convince a friend or loved one to at least drive one before they just stop offering them period here!
http://www.caranddriver.com/features...l-headquarters
