Another low idle thread...
Old Apr 15, 2014 | 08:49 PM
MattyZee28's Avatar
Exclamation Another low idle thread...
Ok... I've been searching for a fix for this for over a year now. Still have no clue what it could be. Before you ask, yes I've searched other threads/forums. Hundreds of them. Every single one dies before they find the problem. At this point I'm just looking for opinions on where the problem could be coming from.
My car runs perfect until it gets up to operating temp. Once it gets there it starts to idle low (about 400-500 RPM) and idle rough like its missing. On rare occasions it surges too. Usually only after not running for awhile. It runs fine when I'm driving, the problem just exists just at idle.
My car is a 94 Z28. 42,000 miles. LT1 A4. All stock with the exception of an adjustable borla cat-back exhaust. Cat is gutted. I've replaced: Spark plugs, Spark plug wires, O2 sensors, Air filter, Battery, and the fuel filter. Cleaned all the sensors I could and tested them as well. 99.9% sure the opti is good. EGR valve is good. Checked, checked and checked again for vacuum leaks. Fuel pressure is fine. No codes what so ever. I've run fuel injector cleaner through it too.
A few more side notes...stick with me...
Recently changed the spark plugs and they were soaked with gas. I have an oil leak somewhere. Nothing major. Never any puddles but it is all over underneath. When i let of the gas the exhaust pops..not sure if any of that really matters one way or another.
I'm sure I'm forgetting something along the way but if you made it all the way through that you're awesome lol. Thanks for any and all advice..Really appreciate it!!
Old Apr 15, 2014 | 10:06 PM
ahritchie's Avatar
Where is the oil coming from? Did it get on the opti? Oil on the O2's can cause issues.....I'd look into that. Could be the dreaded back of the intake oil leak. Who scanned it and with what scanner? I would think there would be codes of some sort with that issue.
Old Apr 15, 2014 | 10:07 PM
Cajun ELESS-ONE's Avatar
did u have the icm checked?? are the o2s tuned for the gutted cat?? mine pops some and it has no cat as well
Old Apr 16, 2014 | 07:50 AM
SS RRR's Avatar
Village Troll
Is the check engine light on?
Never heard of having to do that before...
Old Apr 16, 2014 | 09:23 AM
MattyZee28's Avatar
No lights/codes. Not quite sure where its leaking from. Its not much but i will be looking into it. Oil level is about where it should be and isnt discolored or anything. The O2's are a couple months old. They're still clean.
Old Apr 16, 2014 | 09:28 AM
MattyZee28's Avatar
The ICM was checked too. I guess it could be failing when it gets warm but would that give me a rough idle/miss? Kind of a long shot here but My exhaust has adjustable plates and i have the wide open one in now. So its pretty much a straight pipe. With that plus the gutted cat give me too much flow for a stock car? Still has stock manifolds on it.
Old Apr 27, 2014 | 01:03 PM
MattyZee28's Avatar
Decided to try and sell the car and get a bike lol. Start working on my chevelle more. Who knows...Maybe ill change my mind..again
Old Apr 27, 2014 | 02:03 PM
97lt1camaro's Avatar
I'd be checking the iac valve.
That's where I'm at with my low idle problem. Going to change that and the o2'a today
Old Apr 28, 2014 | 10:05 AM
MattyZee28's Avatar
Done that already. It's good. Not sure what else to check.
Old Apr 30, 2014 | 01:05 PM
96mikez28's Avatar
Is your car on a stock tune? Your symptoms to me, indicate a car running rich. If you have anyone local that tunes LT1's well i would have them look at it. if not i would mail it into of the mail order tuners.
Old Apr 30, 2014 | 06:16 PM
Kevin97ss's Avatar
Check the minimum air flow adjustment on the throttle body, the screw could have backed out or may have been adjusted by a previous owner.
Old Apr 30, 2014 | 06:32 PM
MattyZee28's Avatar
yea its a stock tune.
Old May 1, 2014 | 01:42 PM
96mikez28's Avatar
Excellent suggestion
Old May 1, 2014 | 02:52 PM
nitrous2fast's Avatar
unplug the IAC and see if anything changes...
Old May 2, 2014 | 02:09 PM
MattyZee28's Avatar
I've checked the IAC but I'll check it again. I'll check the screw too.
Old May 2, 2014 | 04:41 PM
BALLSS's Avatar
by "checking" the IAC....how did you do that?
san tool or just look at it?
you should not have to adjust the stop screw on TB if this problem was not there before....they don't "back out" on their own
did you scan or use a volt meter to check IAC volts?, you should if you have not
Old May 2, 2014 | 10:46 PM
hrcslam's Avatar
Have you disconnected the O2's to check if the problem goes away? If the issue persists with the O2's disconnected it's not an electrical/sensor issue. If it does stop with O2's disconnected then it's a sensor.
Old May 3, 2014 | 08:52 AM
MattyZee28's Avatar
I had it checked with a volt meter. Yea, I unplugged the O2's before as well.
Old May 3, 2014 | 08:55 AM
MattyZee28's Avatar
It seemed to help a little when i had them unplugged but the problem didnt go away. Maybe I have more than one issue.
