383 build, questions
Honestly i want to stay away from eagle and step up a little bit in quality. Now i dont know if i should buy a kit or just piece everything together? i have some AFR 180 heads. Figured i could send them to lloyd and mate it with a little bigger cam than im already running. Are my heads big enough? Id like 425-450rwhp if thats at all possible. Possible 100-200shot on top of that at some point in its life.
Just looking for a little help building an LT. I can even shop for used parts. Rather just go the new route though. Pretty much just need a short block and i have all the other supporting mods.
hopefully stay under 4k for a short block assembled and id think probably under 3k for buying all the parts and having it assembled. If i sound off let me know.
One other option is to look in the for sale section and buy someone elses engine and save 50%. I've seen some good ones in there from time to time - people gettin out of LT1s.
Ive been looking around for a used lt1 assembled already just to save cause I know people go ls. Just haven't seen much lately. Don't really want to go ls in my 95 kind of saving my ls project for my 3rd gen
The LS is a fantastic platform and is better in almost every way, but if I see another 6.0 in a LT1 car I'm going to beat the owner with a driveshaft.
I doubt 2 bolt mains will be a problem if your RPMs aren't crazy.
The car will make over 425rwhp and save you a lot of money and unnecessary parts over a 383.
The price of aftermarket rods isn't that much more. I'd shoot for something made from 4340 forged steel with 7/16" ARP bolts. The Scat I beams come to mind.
http://www.hotrod.com/techarticles/h...nnecting_rods/
Rebuilding stock rods is old school and more money and trouble than it's worth with how cheap aftermarket forged rods have become IMHO! Most come with ARP bolts already, you very well might spend MORE reconditioning weaker factory rods by the time you buy the ARP bolts too....
1. On the new budget rods you're using for comparison, do you think the big ends are round, or more specifically how long they will stay round after a few heat cycles? If you think you're safe, guess again. I trust a heat-cycled re-machined GM PM rod more than a budget aftermarket. Not just my opinion, ask somebody in a performance machine shop.
Bottom line: Buy QUALITY aftermarket, not cheap, or.....resize your stock rods.
2. Are you re-using the stock pistons? If so, you can avoid the balancing cost probably required with new budget rods. I know this isn't relevant to the OP, since I think he's going 355, but just for the benefit of anybody else who may go this route.
I'd rather go the extra mile and resize cheap 4340 rods w/7/16 ARP hardware after stretching the bolts rather than reconditioning stock PM ones. Those Scat rods stand up to some heavy ****.
