Y pipe to header weld questions
Old Apr 29, 2014 | 06:15 PM
elis94camaro's Avatar
Default Y pipe to header weld questions
So i had a muffler shop make me a "custom" y pipe for my longtubes and they welded them to my headers. So now i want to buy a y pipe made for my headers but am unsure on how i would go about removing the old one? I do have access to a grinder and reciprocating saw. Do i just cut right after the headers leaving some of the old y on and then just grind it down? I want to completely get rid of the old y pipe because the shop used like a 2.25 inch pipe. Any tips?
Old Apr 29, 2014 | 06:48 PM
Shownomercy's Avatar
Man-Crush Warning
Cut/Grind behind the weld, and pray the pipe comes off the header collector.
Otherwise, make a clean cut at the collector, weld on some flanges and then have a nice clean setup.
Old Apr 29, 2014 | 11:55 PM
Catmaigne's Avatar
I've never used one of these, but I think the cut would be much cleaner most tools.
Old Apr 30, 2014 | 02:53 PM
Whats the name of this tool?
Old Apr 30, 2014 | 03:05 PM
ChevyOwner's Avatar
Tailpipe cutter, you can rent them at Autozone.
Old Apr 30, 2014 | 03:26 PM
AnotherWs6's Avatar
Assassinate whoever welded to your fng headers dude.
Old Apr 30, 2014 | 11:07 PM
pillarpod's Avatar
lol welded the Y pipe to the headers. Shownomercy nailed it on the head. Cut at the collector and just weld new ones on.
Old May 3, 2014 | 08:24 AM
Casey96SS's Avatar
I left my catback on my car when I did my headers and Y pipe. I used v-band flanges to make all my connections. This required a fairly square and accurate cut on the I pipe of the cat back to get it to meet up to the new Y pipe.
I ended up clamping a hose clamp around the I pipe where the cut needed to be. I then made the cut with a nice new sawsall blade using the clamp as a guide to keep it straight and square. Worked good. You can then use an angle grinder to fine tune anything.
