1994 LT1 high idle problem
Did your high idle start before or after the TB swap?
or jump to the end and put the stock TB on to see if it resolves the idle issue....if idle is good then address what you need to do to "mod" the 58....or sell it.
What are the IAC counts at normal idle vs high idle in neutral?
If they are the same, or lower at high idle, it's most likely a vacuum leak.
If the IAC counts don't change at all between neutral and gear then it's either a bad IAC valve or something related to it's control (tune).
If the IAC counts go up with idle speed then it's causing the idle problem. If that's the case, whats the TPS%?
