MAF Malfunction on a '96 Trans Am
How do you check the MAF when it's not connected to the sensor? I'm just trying to buy a new one & not waste $$$ on it. Ive already bought a new MAF off a guy on Craigslist & plugged it up but my p0100 pops up a second later after trying to delete the codes. Any ideas? I tried looking over the pigtail sensor that connects to the MAF but it reads normal volts. Trying to pass smog but I just can't get the code to go away. I'm on my second MAF and don't wanna waste money on a new MAF. Thank you! (96 Trans Am A4)
Ok, I followed the instructions from what the problem was. I went to autozone an hour ago and I bought the 20AMPS fuse. Put it on, and nothing made a difference. I tried deleting the codes and comes on a split second later. I'll see if i put on the pigtail wire wrong (I doubt it but's worth a shot.) This started happening when I put on my nitrous elbow. Any thing else you guys can recommend?
I haven't yet to be honest. The new MAF didn't make a difference either when i put it on. I checked to make sure the sensor was on correctly, I checked the fuses for the 20AMPs and didn't make a difference. Checked the pigtail sensor and it reads normal volts. I plugged in the scanner and I checked the MAF based on how I rev the engine, and on the scanner it doesn't move from 0.1 (From what I remember)
