Solid roller 383 LT1 dyno **7/19 Update**
Old Jul 11, 2015 | 10:42 AM
  #41
PA94Z's Avatar
Thanks! Felt good to make a full pass with no real issues... Trans shifts itself, 5800 stall. Motor is shifting around 7700, which is higher than I want, but actual shift points are unknown Limiter is set to 7850. Data logs are garbage, not sure whats going on.. it flat lines at WOT. Looking at what is there from the run (first 25 MPH) it looks like it shifted into 2nd at 10 MPH....
Here is what I am working with lol.. It picks back up after the finish line...
Attached Thumbnails Solid roller 383 LT1 dyno **7/19 Update**-screenshot-3-.png
Old Jul 11, 2015 | 05:26 PM
  #42
BOLO's Avatar
What PCM/ECU are you using with this combo to be able to command the trans to electronically shift at that rpms? I very much want to know.
Old Jul 12, 2015 | 08:13 AM
  #43
PA94Z's Avatar
Holley Dominator EFI.. will run a 4l60e, or 4l80e. I can command shifts up to 15000 RPM.
Old Jul 12, 2015 | 01:11 PM
  #44
BOLO's Avatar
Thanks. I will have to see about getting one of em'. Hows your trans holding up on those rpms? You must be refreshing them after every season.
Old Jul 12, 2015 | 01:52 PM
  #45
NewOrleansLT1's Avatar
Wow!! I bet that PCM cost a nice grip of money..
Old Jul 12, 2015 | 10:57 PM
  #46
PA94Z's Avatar
The trans has been together for over 4 years.. I pulled it apart before the new motor went in and everything looked great. I put the rest of the anti apply springs in for the 3-4 piston, modified the valve body/input shaft for the non lockup converter, installed a new valve/modified oil passage to bring the over run clutches on in manual 1 and 2. Thats it..I built it with ProBuilt parts and the hydraulics were modified by Dana back when my trans took a **** with a bolt on car.
It only was turning 7100 RPM with the last motor, so I am not sure how its going to like the abuse its going to get this year. It will be back apart this winter to check everything out.
The cost is in line with Fast and BigStuff 3
Old Jul 13, 2015 | 10:45 AM
  #47
sweetbmxrider's Avatar
That is a nice shake down! Clearly some **** to work out and you will be into the 9's. Hopefully you get it ready for some late fall racing
Old Jul 13, 2015 | 10:15 PM
  #48
PA94Z's Avatar
Thanks! I think I have .2 - .3 in the 330 from a good launch/running 1st gear out.. then lots of fine tuning left on the setup. Definitely looking forward to the cool fall air
Old Jul 19, 2015 | 10:36 AM
  #49
PA94Z's Avatar
New time updated in the first post. BIG thanks to BIGSmokey who helped me with the suspension settings! Car is dead hooking and pulling the wheels about a foot off the ground We are gonna see if we can get this car going a little quicker in this summer heat.
Old Jul 19, 2015 | 12:26 PM
  #50
Puck's Avatar
Very nice man, glad you're making progress .
Old Jul 19, 2015 | 01:10 PM
  #51
BOLO's Avatar
Definitely into the 9's with more seat time. Congrats!
Old Jul 19, 2015 | 01:47 PM
  #52
Nostang's Avatar
Congrats on the great times! You should get some 9.8's in the fall air no problem. You have made great progress in a short time.
Old Jul 19, 2015 | 11:18 PM
  #53
PA94Z's Avatar
Thanks guys! Will be out again next weekend doing some more tuning.
Old Jul 20, 2015 | 04:09 AM
  #54
BIGsmokey10's Avatar
Congrats Chris! Some motor tweaks and maybe a bit more chassis tweaking and it'll go a low low 10 high 9 in this 80 degree weather ! Then let that 40 degree air get breathing in that motor and it's game on
Old Jul 20, 2015 | 10:25 AM
  #55
Yes!!!!
Old Jul 20, 2015 | 11:37 AM
  #56
PA94Z's Avatar
Thanks Kyle! It has been a huge help having suspension settings that work so I can get good data on what the motor likes. Lots of testing to do now..
Yes!!!!
Old Jul 20, 2015 | 06:20 PM
  #57
Puck's Avatar
Wait for me dammit! .
Damn wedding and house shopping slowing me down. I have close to $20k saved up staring me down that could make my turd one of the nastiest NA LT1s ever but its for down payment and closing costs .
Old Jul 20, 2015 | 09:03 PM
  #58
PA94Z's Avatar
Hows the saying go.. "Happy wife, happy life" .. You'll get there man. I hope to see some track passes on your new build this year. Tracks open year round in Florida right? We close down up here from November to May
Old Jul 20, 2015 | 11:06 PM
  #59
Puck's Avatar
Yea pretty much year round.
Even though the track altitude is nice though, its so damn hot and humid for most of the year that we still end up with 2500+ DA.
Once it cools down though its in the negative hundreds .
Old Jul 21, 2015 | 03:46 PM
  #60
myltwon's Avatar
Living in FL is definitely a double edged sword when it comes to racing. Plus it makes it really hard to want to part with your AC system racecar or not LOL
