24X swap Vacuum Setup
Dumb question. Is the vacuum on the 24x setup the same as the standard LT1? Im trying to see what ports and such needs to be capped off. I have no A/C or Heat if that matters. I was looking at this diagram below. I just dont like surprises and would like to know.
http://shbox.com/1/1996_evap.jpg
Do I keep the canister purge valve and EVAP solenoid?
Man-Crush Warning
Hook it all up correctly now and be done. I use my EBC as a boost/vacuum gauge so its nice to have hooked up IMO. You can always set all the settings to zero and it will be like you are on WG spring only.
I would hook up the BOV for sure, is it 100% needed for start up? No, but again, work twice...
