Injectors?
Injectors?
I have Ford SVO 30lb injectors and from what I have read they are really noisy which I can attest to. Anyways I want to go with a set of Bosch Series III 30lb injectors. Will I have to have the PCM tuned for these injectors or will it be ok just swapping them out? (I hate the racket these Ford injectors make)
Huh, I'm running red tops too and don't think I've heard them. I guess my roller rockers drown them out. Have you tried some seafoam in the gas or anything like that to clean them out a bit?
Well I have a set of the Bosch Series III in my Caprice and they are very quiet. Not silent but quieter than my red tops. These red tops seem to click away like crazy. They work ok but it makes it sound like there is something wrong with the engine they are so loud.
Yes you will need to have the PCM reprogrammed for the Bosch III 30 lb injectors. Those are what I am currently running. Solomon tuned my car and said the offsets ended up being close to the stock injectors. The car was running really rich after his first tune and he had to keep changing the offsets until the A/F ratio was right.
