possible causes for huge split BLM at idle?
I garaged the car for a couple months because it was so bad i was getting misfires, so i replaced all sorts of ignition parts and got my injectors sonic cleaned. Didn't really do too much to change it. The one time it did seem okay was when i took off the intake (TB forward) to help in checking for vacuum leaks. After i put it back on the BLMs looked good and it ran great (no misfires). The miss never came back, but the BLM split is back, i thought maybe it was a vacuum leak between the MAF and TB somewhere, so i put a new coupler on there, nice and tight, 98% sure there's no leakage there. So i take it out and still have a good split, though not getting clear up to my LTFT of 160 like before. When running at a decent RPM it seems to be pretty okay:
but when stopped and letting it drop down to idle it gets a small split:
which after a few seconds starts to shoot up on bank 2 and turn into this:
I'm not excessively knowledgeable about these engines, but from what i do know, 2 things stick out to me:
1. The IAC is way low, I've read about that causing splits sometimes (though my TB is stock and it's usually a problem with aftermarket from my understanding). I also have a very high idle for a while after startup, like 1600, i don't know if this would contribute to that as well?
2. My TPS 0 throttle voltage seems low, it's supposed to be around .65V from my understanding, does this mean someone closed my TB a bit with the stop screw maybe?
Just trying to get my head around this issue, I've had the exhaust looked over twice for leaks, searched pretty thoroughly for vacuum leaks (smoked the intake with no dice), and i'm stumped. Any insight is welcome!
If my intake was sucking air out of the crankcase, would that be a bad PCV valve or something? I'll be checking/fiddling with my stop screw to see if maybe my blades need adjusted. If my IAC is way down super low where it is, doesn't that indicated they need closed more so the IAC has to open more to keep idle?
thanks for the help
thanks for the help
Edit: I'm still a little sketchy on the tps voltage and iac counts, to me it seems like they're indicating the blades are closed too much, but they're open too far is what your saying? Guess I've got to reverse my thinking...
iac counts being that low at hot idle likely means air is entering somewhere other than the iac valve (throttle plates, vacuum leak, whatever).
lt1s have a special set of idle passages within the intake plenum that are fed by the IAC and the idle air bypass hole that distribute air more evenly at very low airflows than the throttle plates can. those passages can't work without the iac and bypass hole allowing most of the idle air.
by your trims, though, i'd guess vacuum leak or a dead cylinder.
that's a whole ton of trim. 150+ trims are dangerous.
perhaps it was ridiculously lean maybe due to a vac leak and dumped a ton of fuel in to fix it (kind of hard for that to be confined to one bank..). the super low IAC counts sometimes point to a vac leak.
or it was an exhaust leak and due to the inaccurate reading, it dumped a ton of fuel in that bank and it's running pig rich
or you have a non-firing cylinder on that bank pumping straight air into your exhaust... but usually at that point, the iac is struggling to keep it running, not closing to keep it down.
not a diagnosis, just throwin' it out there.
