After 20 years, it's time....
#45
First major component showed up
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
#48
Since these were a custom piston from Diamond, I had them do the coatings as well. It only added a week to the process. I'm interested in seeing how the 2 coatings on these hold up.
__________________
#51
I am also very curious about the piston/wall clearance and ring selection type, I see the ports in the piston so I am wondering if you will be using a dykes style ring or what was the motivation i.e. will it be a 9-second "street car" with "tight" rings or will there be some kind of vacuum assist crankcase pump.
#53
Heavier pin with double oiler
__________________
#55
This type of piston is typically .007 per Diamond, minus .002 with the hard anodized coating for a .005 tolerance.
__________________
