Help!!
Old Mar 2, 2016 | 10:05 AM
Alterian's Avatar
Default Help!!
I have a 1996 gmc sonoma with a 96 lt1 from a z28. I bought the truck with the motor runs poorly. Im getting ready to change the opti, plugs, wires and fuel filter. However I started searching for the o2 sensors and I cant locate them. The truck has headers and the sensors are not in the exhaust anywhere. I also cant find the wiring for them anywhere. Im affraid the person that installed the motor clipped out the o2 wiring. Any suggestions on what I should do?
Old Mar 2, 2016 | 10:18 AM
smitty2919's Avatar
So the truck runs bad, and it has no 02 sensors...buy sensors and fix the wiring.
Old Mar 2, 2016 | 10:20 AM
Alterian's Avatar
Im gonna take it to a buddies exhaust shop tomorrow and put it on the lift. I havent been able to find the wiring at all. Im afraid they removed the wiring all together
Old Mar 2, 2016 | 10:41 AM
smitty2919's Avatar
If the PCM is looking for 02 sensor signals to know how to adjust the fuel trims and the 02's are not there, then it will be confused.
Old Mar 2, 2016 | 10:43 AM
Alterian's Avatar
So I need to find the pcm and try to trace the o2 wiring from there
Old Mar 2, 2016 | 11:12 AM
smitty2919's Avatar
Was the LT1 motor+PCM put into the sonoma together? Or did someone put a LT1 motor in the truck and use the Sonoma PCM?
You need to fix the known issues with the truck. The PCM may have the 02 sensors turned off or something (hence why they are not there). You need to do some digging into the truck and figure out what's going on with it.
Old Mar 2, 2016 | 11:14 AM
SS RRR's Avatar
Village Troll
If the O2 sensors are not present the PCM should run in open loop and should run just fine. The sensors can also be tuned out. If there is a data port for the PCM and you have a laptop you can get scanning software and check what sensors are active. In the meantime, describe how it is running poorly?
Old Mar 2, 2016 | 11:16 AM
Alterian's Avatar
They used the lt1 pcm. Im trying to figure out everything I can out about it. Im not the greatest at electronics or even mechanic for that matter. Its going to a friends shop for the plugs, wores and optispark. He specializes in ls1's
Old Mar 2, 2016 | 11:19 AM
Alterian's Avatar
By running poorly it stutters while at highway speed the rpms will jump up and down by 200 rpm. At times it will crank and crank before it starts other times it will fire right up. Its very doggish and has no power. Its getting terrible fuel economy and u can smell the unburnt fuel from the exhaust.
Old Mar 2, 2016 | 01:33 PM
Alterian's Avatar
So once I get the opti, plugs, wires and fuel filter changed and new o2's installed. Should that take care of the issues?
Old Mar 2, 2016 | 02:00 PM
hrcslam's Avatar
Don't know. What you described can be caused my a bunch of different things.
It could be the opti, or the cap and rotor (on the opti), or the coil, ICM, MAP sensor (are you running a MAF?), or the MAF, broken valve spring (happened to me once), new fuel injectors not the same as what's in the tune, bent valve, bad crank position sensor (the OBD2 LT1's had these), etc. etc. etc.
What mods does the engine have? Do you have the OBD2 port installed? Maybe an OBD1 swap is in order? Because what you really need at a minimum is codes but preferably a datalog. But, you're OBD2 so it becomes a bit more difficult since the engine is in a vehicle it wasn't designed for if the ODB2 port wasn't hooked up.
O2's being removed just forces open loop. IF everything is stock, it will run just fine. BUT that would mean that the condition you are experiencing is a hard fault (mechanical issue).
If you cant scan for codes, then you need to start checking all the systems old school. Check for spark strength with a strength tester. Check fuel pressure. Remove all spark plugs and read them for spark timing, AFR's and heat range. Do a compression and leak down check.
Old Mar 2, 2016 | 02:05 PM
Alterian's Avatar
Im not sure if the truck has a MAF. Actually Im not sure about alot of things lol. I just bought the truck saturday. This is my first lt1. So Im learning as I go I guess which is a big step for me considering Im not that mechanically proficient (although Ive always wanted to be) I just hope its nothing serious or super expensive.
Old Mar 2, 2016 | 02:57 PM
ahritchie's Avatar
Sounds like somebody unloaded their basket case project truck on you, and now you get to try to clean up their mess...sounds fun! . Why not contact the person that sold it to you and ask what all they did (or didn't do) for the swap, post some pics that might help.
Old Mar 2, 2016 | 03:03 PM
Alterian's Avatar
I have contacted the guy. He knows very little about it because he didnt do the swap. The owner before him did.
Ill get more pics of the engine bay once I get home. Lol I wish it sounded fun for me. It would be if I had more knowledge and experience
Old Mar 2, 2016 | 03:04 PM
Alterian's Avatar
U can see in the engine pic that the pcm is just laying there not mounted to anything. Not sure if it virbating or bouncing around would cause any issues or not.
Old Mar 2, 2016 | 04:07 PM
ahritchie's Avatar
It's got a MAF at least! First step would be to have someone scan it and see what all codes there are. There's no telling what parts it's currently got or how it was tuned or if there's sensors missing/tuned out ect. I'd at least zip tie the PCM to something or mount it on the firewall so it's not just bouncing around LOL.
Old Mar 2, 2016 | 04:28 PM
Alterian's Avatar
Thanks for all the help guys. Looks like its gonna be a long process. One piece at a time.
Old Mar 2, 2016 | 06:31 PM
Alterian's Avatar
Ahritchie how could u tell it had a maf? Probably a dumb question I know but Im tryin to learn all I can
Old Mar 2, 2016 | 06:33 PM
hrcslam's Avatar
That thing in the middle of your air intake tube is the MAF.
Old Mar 2, 2016 | 06:36 PM
Alterian's Avatar
Oh ok gotcha. So it able to be read at auto parts stores like other vehicles?
