Can a stock Lt1 just headers and exhaust run a cam
I have a stock 94 lt1 Camaro with headers and exhaust i recently got the heads done . And I was wondering if I could run a lunati 231/239 cam?
You got the heads "done". What does that mean?
Did you get them ported?
Were they milled?
Or were they 'just' cleaned up and rebuilt?
A 231*/239* cam is a lot of cam for a stock displacement LT1....especially with stock compression.
Bigger ain't always better........
KW
Were they milled?
KW
I'm fully built with a similar cam that the OP wants. I wish I went smaller...... Don't get me wrong the cam is great, got tons of power out of my build, but with that cam (I'm more advanced than his though I think) and my ported heads I have to rev to 7k to get everything out of it. My hyd rollers and 3/8 SA RR don't like 7k, I'm rev limited to 6800 (and thats pushing it) now and know I'm not using all of the cam. It'll be even worse with unported heads and less cam advance.
^ Agreed, I had that cam with my old cam only setup, not bad on the street but still sounded quite choppy.
To give some perspective, I shift around 6600-6700 RPM on with a forged 383....on a stock 350 probably gonna need more like a 6900+ RPM shift point to get the most out of it as previously mentioned.....very risky on stock rod bolts (ask how I know ); not even mentioning drivability concerns loss and of low end torque.
Also you say stock other than headers exhaust....CAI and a tune would be mandatory at least as well. 3.73 Minimum or 4.10 gears would also be recommended AND a stall if auto or it will really drive like crap.
Just throwing a big cam in stock LT1 is a half-baked idea basically.
With stock compression and displacement, it's a good idea to keep the intake duration in the mid 220s at the most.
That 231/239 cam would probably prove peaky and thin on grunt down low in a stock longblock. You'd also have to rev it to the moon to get the most out of it, courting the likelihood of rod bolt or bearing failure in a stock engine. At the minimum I'd want ported heads and a full point or so more compression than stock to run that cam.
In my car I have ported heads and more compression and am still running less duration than that on both sides.
I just figured it's a smaller cam (duration wise) then cc306 and gm847. People ran those on stock heads and long blocks and didn't leave much on the table in terms of being over cammed. A smaller cam may have run better for sure.
I'm not sure what you mean by "leave much on the table in terms of being over cammed". In the real world, I'd be willing to bet a properly specced combo with a smaller cam will be faster that a slapped together combo with little supporting mods to run a big cam SAFELY; not to mention way more fun to drive than a bucking, no low end, peaky engine that's on the ragged edge of reliability.
Yeah, that's too much cam for stock cubes, heads, and compression IMO, it's gonna drive like crap on the street most likely and be a dog down low.....I run this exact cam in my 383 with ported heads and 11.4 CR, 4.10's with 6spd, it's real nice on a 383 with ported heads however!
Just because it technically can be done doesn't mean it's a good idea at all. Kinda like 1.7 RR's
Guy wanted to know if he could run it, simple answer is yes, people have run bigger. Best idea? No.
I'd love to throw a stroker under my build. The drivability of my set up is good, but I'd take a few hundred RPM drop up top and a 20-30hp increase, with even better low end torque! I just can't convince my self to pony up for the 383 rotating assembly + machine work. I'm at 11.8:1 right now too, so my SCR with a 383 will go up too. My low end torque right now is good enough to climb a 7% grade in 6th at 70 nice and smooth, it'll even accelerate extremely slowly up that hill in 6th.
Do it...mine has just as good drivability as it did with the little 219/227 cam when I was cam only. I can poke along going 45mph in 6th with 4.10s with no issues.
