Help Trouble shooting Please
I just rebuilt my brothers LT1 which had a spun rod bearing, it's a 97 SS, M6, 410 gear, stock bottom end with cc503 cam, 1.6 roller rockers, 918 springs, SLP shorty headers, BBK throttle body, aftermarket MAF with a Solomon tune. Car was previously stock with the fore mentioned bolt on's and stock tune. Spun a rod bearing because he over heated it. Heads were milled .08 block was cleaned and checked prior to rebuild.
On first start up car ran very rough, would barely idle. Car was running lean and eventually gave me 2-DTC's. Low voltage on bank 1 and high voltage bank 2. I replaced both 02 sensors with Denso's for now. This improved drivability and idle quality a lot but it's still not right. And doesn't have a lot of power. Here's what I know:
Car dies when coming to a stop
Doesn't like to start unless it gets a little throttle
Car will idle all day just a little rough
If I unplug the MAF the car will not start.
TPS is adjusted correctly .67v closed and 4.65v open
Checked resistance on IAC and checks with in spec .51ohms on both circuits
Timing at idle is 30 degree and goes as high as 40 under heavy throttle?....
Fuel pressure is 44 psi with vac line off holds steady at 40ish under heavy throttle (under a load)
No DTC's currently present.
EGR is obviously deleted, along with emissions stuff
I can record some live data with my scanner but I'm not sure what to look for really. It doesn't appear I can read Idle air counts with my scanner? I have faith in solomons tune, I just need help in what to trouble shoot next?
Car is still running lean
Thanks
Paul
I'm gonna try a factory MAF and take a look at the fuel trims as 1995 T/A suggested. I believe my scanner lists fuel trims in %, if this is true at 100% throttle should my trims be at near 100%?
I assume the BBK TB worked without any issues before when stock?
Odd that you would get low voltage on one bank, then high on the other. Makes me think that something between bank 1 and 2 has been mistakenly swapped around.
If the car will not start with the MAF unplugged, one of the inputs for speed density might be missing. Are the IAT, MAP, and coolant sensors plugged up and working fine?
Are any fuses blown? Under the hood and under the dash fuse box cover?
Are you 100% sure that the plug wires from the Opti are on the correct plug?
