Comp Ultra Pro Magnum - Locks & Studs?
I'm currently running the SA 3/8" Comp Magnum 1.6 roller tip rockers with Comp hardened 5/16" push rods. I'm planning on upgrading to the NSA 7/16" Comp Ultra Pro Magnum rockers with Isky adjustable guideplates. Does anyone know which studs and polylocks I'll need and if it will be possible to retain the stock valve cover?
Thanks,
Jim
Thanks,
Jim
Jim
on Comp "Pro Mags", and assume the same for "Ultra Pro mags" you will need to trim part of the baffle inside the VC. No big deal. I just used a dremal with a cut off wheel. Took only minutes. Clean VC after to remove any metal shavings.
get ARP # 134-7103, 7/16" studs.
cut baffle on intake side of VC
I called one vendor and asked about the poly locks. He told me they weren't included. Trimming the baffles aren't an issue. I'll check into these PN's. Thanks for the info.
yes Sparton I know they don't have the shank under the head...but with My ISKY adjustable they work great so I can slide/adjust them as needed. been on this motor for 10 years now. 1:6 Pro Mags NSA
