New LT1 owner
O2s are fairly easy to replace.
Save some money and do them yourself.
But yes, an exhaust shop can do it.
But make sure you research the code first.
First sort out the 02 issue. AC Delco only on those. If you can turn a wrench and connect a plug....you can and should do this yourself. With the long tubes you likely need extensions so do a search on where to get those. If the headers do not have bungs for the 02's to screw into than you need to go to a muffler shop and have them weld them in and at that point just install the 02's
Don't run a 160 stat unless you have the PCM tuned for it. A mail order tune for a stock motor with CAI, headers will be fine. You will need to bleed the cooling system if putting in a 160 stat
Stay away from Aeromotive anything. If you do need a adjustable FPR get a BWD (Borg Warner) one which should be able to get at local auto part store. It is a direct fit for the OEM one
My car came with a K&N CAI. It is nice, fits well, but getting the filter on is a PITA. I took it all apart to clean it and it was a 2 person job to get the filter on. One to hold it the CAI from the top, the other to push the filter on. I put a Moroso CAI on a 1995 I owned and don't remember it being that difficult to get the filter on. I think if you have headers/exhaust a CAI is mandatory. More air in + more air out = more power. You have the exhaust end of it taken care of.
I installed an SLP airfoil. Don't know if it works or not. But it was cheap and easy to do so why not?
I installed a 160 thermostat. Easy enough to do (you have to take the elbow off the throttle body to get to the thermostat housing) I also reprogrammed the fans with a Hypertech I bought off Kijiji. I would suggest draining some antifreeze before install. Some came out when I installed it, and I didn't think it was much until I moved the car and there was a substantial puddle below the car. Thankfully the opti didn't get wet. Also, I didn't have to bleed my system for some reason. It was fine. After I put everything back together I ran the car with the rad cap off for about 15 minutes. It "burped" a few times while I did that so I assume it was letting air pockets out.
On a sidenote, the LT1 came with a 180 thermostat from factory so going to 160 isn't a stretch but is pointless unless you reprogram the fans. Also, some say your oil will not get hot enough to burn off contaminants but some say it does. I think on short trips it would be an issue however it would be with any car not getting to operating temperature. But it def runs noticeably cooler with zero effects as far as I can see. I believe my car has the intake manifold oil leak, and I haven't smelled that slight smell of hot oil since I did the thermostat, however it def does not fix the problem. I think the engine just does not get hot enough to burn the oil seeping from it. Could be my imagination, too. lol
Some say your fans are running all the time but I didn't notice it at all. When idling they come on more often but not much. That is my experience, some say otherwise.
As stated, I bought a Hypertech off Kijiji. Some like them, some don't. It depends on what you are doing. If you want to reprogram fans, get new gears, different sized tires, change shift points and firmness, rev limiter, I would say it is fine. The nice thing is you don't have to send the PCM in to anyone, and you can change it back to stock if necessary. It comes with a tune and some say it works, some say it doesn't. I understand that if you install the 160thermostat in conjunction with the Hypertech tune it "may" work. Only one way to find out, which I will do when I change my tune with a rudimentary before/after with a g-tech. But I don't think it is the answer for a serious tune if you get heads/cam etc. Not a chance.
I did the throttle body bypass. Went to Napa and got a 1/ 8" barb fitting, two #6 hose clamps, and two nipples to cover the openings when you remove the hoses. Good luck. I never swore so much before. The drivers side is easy to take off, the passenger side was a bit**. Some people cut the hose off but I refused to and payed the price with lots of swearing, skinned knuckles... also, I didn't lose any rad fluid but I did use a turkey baster to take some out of the rad just in case.
If your car was mine, the first thing I would do is get that check engine light taken care of first. The hypertech can read codes, or you can buy a cheap code reader from Amazon for under $20. Or take it to someone to read them but I want to do it myself so I know exactly what is wrong and what to expect when I take it to a mechanic.
Only thing i can see from looking under the car are the collecters hanging down on each end and they are welded to the y pipe.
My buddy has a 91 gt he bought new with 21k miles that has 1035 rwhp! On 110 oct. He told me today he has an actron scanner of some type that we can use to diagnose the codes.
Im just excited to have gotten another fbody to play with and mod as my corvette has very low miles and i want to leave it stock so, i im pretty excited!
There again, i appreciate the responses and advice and i will post what my findings are when i get the work done.
Hell....I still have a OEM regulator on my 475HP (or so) 396ci solid roller LT1/4.
Seriously.....it ain't needed!
KW
It will likely cause you more problems than solve.
Elsewhere in this forum, some people are recommending going with the oem ac delco o2 sensors for a c5 corvette rears and im under the impression that they already have the extended harnesses with them? Shall i get those or just get the original ones for my car and extended harnesses?
I installed the MGW short shifter yesterday and also put in the bronze shifter bushing along with a camaro ss leather hurst shift ****. Its awesome!! Only problem i have is that its kinda hard to get into reverse? Anyone else have this problem? I noticed that the under the console shifter boot was kinda tight. Maybe i should have cut a little bit off it to better acclimate the new shifter because of its design? Anyways, thanks as always for any input and advice.
