This is going to sound silly, but.....
A baby cam with a low idle rpm and open exhaust can sound just as big as a donkey dick cam with a full exhaust and higher idle rpm.
starting the car with a cam with the stock tune with a lower idle around 650 rpm it will have more of a "chop" sound but beyond that the tune needs to be adjusted for different timing, fuel trims, etc to run optimally.
if you are more concerned about having a chop sound ask your tuner to lower the idle rpm...but you may sacrifice drive-ability and performance some.
