Oil pressure check?
I started my 1996 bird (LT-1) today and low oil light stayed on. I didn't drive it. Where can I check the oil pressure at mechanically? Is there somewhere to hook a actual gauge to? Thanks.
http://shbox.com/1/aux_oil_port.jpg
I'll give some quick history. I put the car in storage last fall. A few months before that I put some Lucas oil additive in it because it had a tick and I was hoping this would help but it made it worse and it might have caused the issue i'm having now. I don't want to leave the car in storage this winter because, although I checked it every month, the mice go into it just this last month and a mold issue is going on in the interior. It was a bad choice for storage. I'm just going to leave it out in my driveway this winter so I'll have easier access to it and can monitor things better. I'll be using some poison this time too. I couldn't use that where I had it because the owner asked me not to. Thanks again.
Now that more is known, more suggestions can be given. You can test the gauge just by unplugging the connector from the stock sensor. Your gauge should peg to high with key ON. You can also check your sensor with a DVM to get ohm readings that correspond to pressure (~90 ohms=high pressure, ~10 ohms=low pressure). That way you can see if it is actually reading pressure.
