414 Stroker??
Old Jun 26, 2004 | 09:49 AM
Jordan57's Avatar
Default 414 Stroker??
Okay up at sonic last night I was talking with all the local lt1/ls1 guys and this one lt1 corvette owner starts talking to me about strokers. He says he has a 383 stroker....I believe that....however this winter he's going to freshen it up and make it a 414???? Is that even possible? I've seen ls1 cars up to 427ci...but how come the LT1's don't get that big? And also if there is a 414 LT1...how come there isn't a glamourized short block like the 355,383,and 396? Sorry about the newbie style questions but I am pretty interested in this
Old Jun 26, 2004 | 10:30 AM
dhdenney's Avatar
It can be done. It just isn't done much probably due to durability issues. I would venture to say 414 is max for the LT1. The LS1 design is drastically different and is the reason for such large stroker applications. The 414 LT1 would require a lot of machine work and some of the parts are a little more speciality which would mean more $$ and why the combo isn't offered up as an off the shelf short block/crate motor. 414 cid is 4.00" stroke and 4.060" bore, pretty much maxed out.
Old Jul 8, 2004 | 06:25 PM
XxXTransAmXxX's Avatar
I am currently building a 396 and it alone wraps up wayy more money than even a 383 cuz of the odd ball issues of off the shelf stuff for a 338 makes too high of a CR, so you have more custom parts....but IMO well worth the more "RARENESS" over a 355, or 383
Old Apr 5, 2008 | 11:45 PM
ls6musclehead's Avatar
On the ls1 there is more clearence for the 4.100 stroke around the camshaft. The lt1 has first gen dimensions. Rods won't clear.
Old Apr 6, 2008 | 01:44 AM
Speed Density's Avatar
hashtagBMW
There would also be no point to have a "414" other then saying "Hello, I have a 414". Your going to have to do a lot of work to even make that work, wouldnt be suprised if you pushed water either.
Tony.
Old Apr 6, 2008 | 09:55 AM
the_merv's Avatar
That's pushin it for a SBC Block..
Old Apr 6, 2008 | 08:31 PM
TAEnvy's Avatar
A buddy has a 445 LS2. I would love to have a 427 lt1 id be in heaven but if I wanted that from an LTx itd have to be LT5 and DAMN that stuff is expensive.
Old Apr 6, 2008 | 10:03 PM
the_merv's Avatar
If you look into it.. the LT5 Bore X Stroke is very, very close to the LS1...
Makes you think for a sec..
Old Apr 6, 2008 | 10:11 PM
TAEnvy's Avatar
I almost bought me a ZR1 a while back and they are doing some badass stuff with that old motor.
Im talking over 400cfm heads
Old Apr 6, 2008 | 10:17 PM
the_merv's Avatar
They must have some good funding..
Old Apr 6, 2008 | 10:49 PM
Formula350's Avatar
There's a place in MN I remember seeing while looking for pics of bare LT5s and they make 427 LT5s I'm 90% sure of, and that's for a LASTING motor.
427 I think is also the max on a standard casting SBC. Won't last long though with that thin cyl wall. Maybe not LT1s, but I'm pretty damn sure there were quite a few 427 SBCs back in GENI days.
Old Apr 6, 2008 | 11:01 PM
the_merv's Avatar
Some guys in NY made a 454ci SBC Gen I out of a 350 Block..I remember reading it a while back..
Old Apr 7, 2008 | 12:49 PM
sdm1234's Avatar
that's rediculous... a 454? now that's A LOT of cutting!!
Old Apr 7, 2008 | 05:10 PM
James Montigny's Avatar
With enough funding and enough stubbornness, anything is possible.
Great for bragging rights, not so good for bang for you $ or durability (IMHO)
Old Apr 7, 2008 | 05:25 PM
camar0corey's Avatar
Considering the way most of us drive on here, I bet we could wreck a 414 LT1 in less than a month.
Old Apr 7, 2008 | 07:19 PM
Ironxcross's Avatar
very true!
Old Apr 7, 2008 | 07:20 PM
the_merv's Avatar
You get used to it..you see the speed that you used to going.. difference is that you get to it ALOT faster..
Old Apr 7, 2008 | 09:09 PM
Formula350's Avatar
That'd be with the World's Motor block, those CAN do 454cid and safely too!
Originally Posted by World
Maximum Bore: 4.200" DO NOT EXCEED
Crank Clearance: 4.000" stroke (H-beam steel rods)
So, We'll go with a safer 4.190 with a 4" stroke, we get... hmm only 441cid ... Oh well, I might have been mistaken and it was the LSx version that could do 454...
EDIT: OK I looked, and the LSX Warhawk block, at max everything... *drum roll* 481cid SBC GENIII
Old Apr 7, 2008 | 11:25 PM
TAEnvy's Avatar
I thought I was reading about 500ci LS motors a while back maybe I was wrong and carcraft did a test on a sbc 454 vs a bbc 454 a while back so someone makes a monster mouse.
Old Apr 8, 2008 | 12:37 AM
jester1614's Avatar
holy old thread batman
did anyone else notice that this thread jumped from 7-8-04 to 4-8-05
