4L60E to T/56...little wiring help please and re-flash?
So I have been searching the site for a long time, and just can't find what I need...I keep seeing reference to "re-wire/Re-pin the harness for the T/56 swap. But I'm not finding any details or a diagram, can someone point me in the right direction please?
My daughter bought the car to use to engine and tranny in my old '89 IROC, but the car's a bit to nice to take apart, it's a '97 Z/28...needs some love, but what the heck...I'd rather we just getting it right in the '97...when I ran the RPO codes, I see the car was originally a 4L60E...could be why there's harness's hanging under it
So anyways, I want to use the harness I have in it, re-wire/re-pin it, and then do whatever the PCM needs to be redone.
Little guidance please?
Thanks
Thanks
I'll check if I have any references from back in the day. I did a full swap of auto to T56 on my 96 Z28. there was only one wire that needed to be hooked up to the ECU and that was for the lockout solenoid, the ECU itself I think I took from the doner car that had the T56 on it. Although, I might be mistaken. I'll see if I can get back to you on this soon.
On 96 and 97 cars, there's no PCM wiring that needs to be re-pinned, it already exists in the A4 harness. VSS is the same between both transmissions, mine was able to reach with no extension.
For reverse lockout, use the pink wire (pin E on the big A4 connector) for 12v switched power. Then use the brown wire (pin U) for the other side. Splice your reverse lockout pigtail into both of those.
For CAGS, if you so choose, use the same pink wire for power, and the white wire (pin S) for the other side of the circuit.
Great info! I assume the large A4 connector is he one to the tranny?
I'll look into eliminating the CAG's later, as I recall many consider it a PIA.
Thanks again!
Thanks again!
I did nothing but swap the speed sensor over. I have no reverse lockout so it's quite annoying. I am 220lbs and seem to be the only person who can get my car into reverse with one hand. I had the car re-tuned by my tuner for manual and the car notices nothing. Runs like a dream.
Yes, this connector. If you look closely inside the connector itself, you can see the pins are labeled.
CAGS can be completely disabled in the PCM, which I'd recommend. But the wiring is there for you. I also have info on all the interior wiring, since I've done it a couple times. Any competent tuner can flash an A4 PCM to an M6 one, I'd recommend Moe. Stay away from PCM For Less.
easiest and cheapest way to retune pcm is to use your laptop and download eehack it works great. also good to use to tune pcm for rear gears. i recommend eehack for all lt1s...and best part is its free...but dont cheap out on the odb to usb cord u get, i did the first time and had a shitty connection, fried my pcm. wasnt the software, it was the user haha.
