What can I delete off an LT1 Intake ?
Village Troll
Along with EGR, EGR solenoid, EVAP solenoid, HVAC, opti vacuum (if so equipped with vented opti) and PVC vacuum are all on the intake. Chose your poison.
Also, if you block off the EGR port where the EGR mounts you do not need to block off the exaust gas port on the passenger side of the intake. That port s plumbed into the EGR side and once you block that off you're good to go. Just FYI.
im guessing your talking about capping off the smaller/skinny nipple right above the PCV valve ? Ive already done that.. air pump was also deleted.
