just put some hooker LTs on my 96 LT1, now throwing codes
I just put some hooker LT's on my 96 LT1, and i didn't buy the LT's with the egr and air pump option. i just put them on and my car doesn't run too good. MY car is throwing P0100 and P0400 codes. What is this??? MY EGR and air pump are not hooked up does this have any affect. Is there any way that i can bypass them or something so this will not happen? ANY help is appreciated Thanks!!!
I recently took my car to HPE horse power engineering and they deleted my EGR code, so it doesn't throw it anymore, but my MAF code is still being thrown. P0100 I have borrowed my friends MAF and the code is still being thrown any help guys THX
Ok thanks to the person that told me about the fuse in the relay box under the hood, i have fixed the problem with my reverse. The fuse that reads 'engine sensor' under the hood, inside the fuse relay box was burnt, i replaced it and now my P1657 code is there no more, but MAF is still being thrown, P0100. Yesterday i reset the computer by disconnecting the PCM fuses and my check engine light went away for the whole night, but when i started it this morning, that ORANGE light stared me in the face!!! I pulled out the PCM fuses and the light did not go away any help guys???
Originally Posted by FIREHAWK #7
Ok now my car is throwing codes P0134 and P0300 and it's not throwing the MAF codes!!! THis is starting to suck
Regards,
Chuck
I personally don't worry about the codes if it's running ok. I've had my scanned once and I never solved any problems with that. Since then, I just don't worry about it.
