What Is The Next Logical Step (Modifications)
Car - 1997 Z28
Trans - A4
Miles - 75,8XX
Performance Mods Only:
- Full CAI
- Pulleys (UD on hub and OD on alt)
- MM Catch Can
- SLP Airfoil
- 1 LE Intake Elbow (had one with opti vent now have a new non-opti vent 1LE)
- TorqHead 24X VC mounted
- Pacesetter Long Tube Headers
- Pacesetter ORY/Removed all cats/dumped before real axle
- PS Cooler
- Built “10 Bolt” – TA Peformance Girdle/Stud Cap Kit/Motive Orange 373 thick gears
- Strano Springs
- Bilstein HD shocks
- HAWKS HPS pads all around with BrakeMotive Slotted Rotors
- NITTO NT05 275/40/17 front and NITTO NT05R 275/40/217 rear
- Full UMI everything front and rear (full suspension is single on car adjustable are Poly/Roto, Poly/Rod or Delrin/Rod. Also included all Blaine Fab front sway mounts and all UMI delrin steering inserts. Every suspension component they make for our cars I pretty much have minus the driver side PHB lowering to make it level, but I have to get their upper bar to at the same time.
- All new shock mounting hardware/inner and outer tie rods/ball joints etc.
- FLT Level 4 4L60E with large cooler (Maybe TRU-COOL 40K?), Trans Go HD2 Shift Kit
- YANK 3600 Stall?
- Motor Work (LE or AFT heads and cam or go 383)
- Ford 9” but waiting till my 10 bolt dies
Thoughts/Input?
Rear end crossed my mind but I'll wait till it explodes lol!
I will say when I do the motor I'll be going KOOKS or ARH headers etc. I'll be selling off my Pacesetters or get the AIR/EGR welded shut and keep them as backups. I already have the AIR pump taken out and everything capped off.
I think this is the cooler I have, but I may have the bigger version. Cooler trans temps makes everyone happy.
https://www.jegs.com/i/B%26M/130/702...CABEgKNOPD_BwE
Only advise on trans cooler, spend the coin and go braided SS with proper fittings. Blowing off cooler lines sucks, as does leaking cooler lines.
Even still on the stock or bolt on setup most guys see a pretty significant drop in ET from a good converter and tranny so the car is likely to pick up and you'll kill 2 birds with one stone.
I see two things in your current setup that will be opportunity areas once you hop the motor up with H/C or stroker: your current CAI and y-pipe. I'd suggest converting to an LS1 lid setup if it will fit under your hood. I'd also hack off your current Pacesetter y-pipe merge and weld on a good quality 3"-3.5" or 3"-4" merge or just go true duals. The single 3" exhaust (assuming that's what you have) will hold you back when the motor is pushing 450-500+ crank horsepower with H/C or stroker plus the merges on many of these y-pipes is just garbage. Lot of LS guys run the Flowmaster merges and pick up good power from that, you'll just have to change increase the pipe diameter coming out of the Y and get a new muffler. May even help on any rasp too.
Your rear may never be an issue so I wouldn't worry about it now. I've been cutting 1.5 60 foots on my stock 10 bolt for a decade now, they tend to live behind autos.
I was thinking their best 4L60E possible it is like $2,000; I’d go with SS lines and the best fittings I could get my hands on. I went all metal fittings and lines with flared ends when we did my PS cooler.
Heads probably LE2 and his custom cam. I don’t know if I could do his LE3 heads on a stock bottom end.
Overall goal is to make the most reliable and high powered NA LT1 I can. I drive maybe a few hundred miles a year with the car from April/May to end of October early November (as long as no snow etc).
Thank you for your input!
initial ideas - kooks long tubes/kooks y-pipe or merge and GMMG Cat-Back exhaust with a low profile cut out would all be done with the heads and cam.
