Header gasket leak
Old Nov 8, 2019 | 06:50 PM
Vicious95Z28's Avatar
Jon, if the bolts are long enough you can sometimes use some lock washers to help prevent the bolts from backing out. Have you had any luck with getting the leak stopped?
Old Nov 8, 2019 | 07:26 PM
Jon M's Avatar
see post #16
Old Nov 8, 2019 | 10:08 PM
Originally Posted by Jon M
see post #16
👍 my bad
Old Nov 9, 2019 | 04:01 PM
Jon M's Avatar
And the leak is back. Same spot. Bolts are tight
Old Nov 9, 2019 | 05:36 PM
Jon M's Avatar
Also went back and found this pic of the header. Are those scratches maybe my issue? Typo in first post. Bought these used not new
Old Nov 9, 2019 | 05:43 PM
Floorman279's Avatar
I had a flange that was bent. the tuner used 2 metal gaskets and it's now fixed
Old Nov 9, 2019 | 05:58 PM
Jon M's Avatar
Does not appear bent from what I can see, but I have some choice words for the shop that said it was all fixed. Lasted 5 miles.
Old Nov 9, 2019 | 06:04 PM
old school trick apparently, I would try 2 metal gaskets
Old Nov 9, 2019 | 08:41 PM
Shownomercy's Avatar
Man-Crush Warning
Percys dead soft gaskets worked wonders on my setup, spray em down with copper rtv then install em.
Old Nov 10, 2019 | 06:54 AM
atlantadan's Avatar
Again - Remflex graphites. You will not leak.
Old Nov 10, 2019 | 08:12 AM
Jon M's Avatar
i may try these next but that’s what they said about Percy’s. That’s what they said about Fel-Pro 1406’s...
Old Nov 10, 2019 | 11:16 AM
  #32
I’d say check the flange with a straight edge but I know you really don’t want to pull the headers completely out. If you do pull it the area where it’s leaking should be obvious. Check it with a straight edge and find out if it’s high or low in that area and try to straighten it if possible. Header leaks do suck man, I can’t say I’ve ever had as much trouble as you’re having.
Old Nov 10, 2019 | 04:35 PM
  #33
BALLSS's Avatar
not what I would call a "smooth" finish. The FelPro 1470 have always worked for me but you could try, since the FelPro didn't work for you, the ones AtlantaDan notes. Might want to hit the flange with a long sanding block to smooth it out...assuming the flange is not warped
http://catalog.remflex.com/CHEVROLET...ket_p/2042.htm
If they don't you have a warped flange..
Old Nov 10, 2019 | 04:41 PM
  #34
Jon M's Avatar
Your advice has always been spot on. What’s the difference between Fel Pro 1406 and 1470? Also I’ve seen people recommend the Remflex 2022 vs the 2042. I want to try remflex last as I read once they are on, they leave quite the mess that has to be scraped off. Gonna call the shop tomorrow to see what they will do. Also supposed to get 4-6” of snow so....anyone wanna buy a car lol?
Old Nov 10, 2019 | 09:12 PM
  #35
BALLSS's Avatar
Jon
The 1470 is for LT1/4 "D" port heads. The 1406 are Gen 1 SBC D port...I have always used the 1470's on my LT1.
https://www.summitracing.com/parts/FEL-1470/
I have never had any luck with copper gaskets and never used the Remflex so can't speak one way or the other about them. Atlanta has been around the block so if he feels they are good they should be. With that said I use the FelPro 1470...but any gasket is not going to work if the flange is warped/ Holding a straight edge on the flange and running a flashlight behind the straight edge to see if the mating point of the straight edge on flange reveals low spots is something you might want to do if the header can come off enough to allow you to check that.
If you are having someone install these than you should re-tighten them after a couple of heat cycles. I use the box wrench with another box wrench wedged on it to add leverage.
Old Nov 10, 2019 | 10:05 PM
  #36
Jon M's Avatar
Jon
Well I have an email into Remflex. Going to start with shop, I checked for tightness after the 12 minute drive home and they were still tight. If they don’t fix it, its gonna take a 5 month winter slumber before I mess with it again
Old Nov 11, 2019 | 11:45 AM
  #37
Jon M's Avatar
Shop is going to get me in Friday. Remflex said this, “
Hi Jon,
Thank you for your interest in Remflex Exhaust Gaskets. You can find out which of the parts is right for you using the port dimensions--the 2022 is 1-7/16" x 1-3/8", as opposed to the 2042, at 1-7/16" x 1-7/16".
Regards,
Rebecca“
Old Nov 11, 2019 | 12:31 PM
  #38
SS RRR's Avatar
Village Troll
Old Nov 11, 2019 | 06:42 PM
  #39
Jon M's Avatar
Well in case anyone was wondering, Lloyd Elliott matches the exhaust side of things to a Fel-Pro 1406. So got that part right so far.
Old Nov 12, 2019 | 05:06 AM
  #40
atlantadan's Avatar
They do leave a bit of a mess, but its nothing that is difficult to remove. You can use a plastic edge scraper and it comes off with zero effort. Be careful with them during handling. I've never broken one before install, but I can see how it would happen.
