Fuel pump slection
Right now I have an NA 383 and while the tank is out I figured I put a new pump in. Soon as my 70 chevelle is done I'm gonna pull the motor back out of the camaro and have the underside of the car cleaned up and repaint the car. While it's out I want to redo the motor and add a supercharger to it. So probably in the next two years I'll be doing all of this.
What fuel pump setup should I pick.
I also dont want to do something that negatively effects how the car runs. I'm definitely going to do it because a ) I am getting a little rust under the bottom of the car. I have had this car since 04 this car stated out life as a 3.4 by and I have gotten it this far. B) I cant stand the cam I have in this car so I want to change to a diffrent setup anyway.
I was looking at the racetronix kit from the ws6 store.
Twin 255s are a staple of getting folks ~700hp area
http://www.lonniesperformance.com/fbodyfuelsystems.htm
Or, a big walbro 450 but taht will not fit in factory bucket
Personally, I would build for what you have and upgrade later. Dropping the tank is not that bad and is much better than cycling a crap ton of fuel around your tank gaining heat.
AFAIK, the LSX tanks have a different fuel level sender, so your LTX gauge won't work. It can be modified but just a word of caution.
The tank is easy to get out its the axle that is a pita. Of the tank was in another location that be diffrent.
lol oh i know, i saw all the naysayers in various write ups when i was researching the mod. if you have full carpet in the car you cant even tell its there, chill out. 90% of these cars aren't worth more than 6k anymore anyways
Just be careful when cutting it out. I was a dumb *** teenager at the time and the sparks fubbered my glass up, something I didn't realize until later on when I had the hatch glass tinted. If I didn't get a free hatch with good glass from a friend I'd be mad as hell so mask it that ****** off good so you don't make the same mistake I did.
