Operating Temps
Thoughts are perhaps a larger/thicker new core, but I think that will just take longer to reach temps and reach same peaks.
Pull existing EWP out, and either send back for rebuild, or throw money away on a new one. (prob 10 years old at this point)
Go crazy and run dual pumps, also throwing money away
You've already said flushing the engine helped, but it looks like your ambient temps also dropped so that could be moot. It could be your thermostat or your water pump is going out. At 50°f your engine should be riding the thermostat (if a 160° thermostat then the temps should basically be no higher than 165° ish). One thing to remember is that, depending on your highway rpm, EWP tend to run hotter at highway speeds than lower speeds (due to their lower GPM vs a mechanical pump at more than about 2K rpm) while mechanical pumps run hotter at lower speeds and cooler on the highway for the same reason.
180° coolant temps isn't anything to worry about IMO, but if it were my car I'd want the coolant temps riding the thermostat at highway speeds if it's only 50°f ambient. For comparison, it was 109°f ambient here today and my coolant temps only got to about 185° with the AC on at 50 mph (no fans).
I would try the fans on at highway speeds and see if that helps, if not replace the thermostat, and if still no improvement replace the EWP. If the fans do help with temps, modify the air dam/shrouding.
I've had this car since 1997 with stock radiator and it would always stark getting bad heat soak when you beat on it in the summer time especially; and then with 383 came a 160 stat, Meziere HD electric WP, fan tuning by PCM for less... which works well enough when it's below 70 degrees outside and you aren't stuck in traffic. Added bonus, it looks pretty and shiny under the hood, no unsightly, fugly plastic tanks, also the aluminum tanks hold a higher capacity of coolant, core is 2"+ thick, 3 cores vs 1. Now highest it will go (75% water/ 25% coolant + bottle of water wetter) is 185-190, that is with the low speed fans on after extended idling. Haven't yet heard the high speed ones engage because it's just too cool!
I was barely able to squeeze it in with the stock fan shroud; which needed some slight further modification with the dremel tool around where the long *** Meziere WP sticks out.
Downside; the low coolant sensor won't fit without leaks, even tried bigger O-rings; so just eliminated it with the plug; I check my temps regularly anyhow and the coolant level, I don't need the idiot light anymore which often comes on for no reason anyway. Not to mention I've had issues with that sensor leaking on my old LS1 car
Long story short; save your money on expensive waterpumps and just put in a ebay radiator. I got mine from Speed Daddy
Additional 3rd party source confirming there's major gains to be had by upgrading the weenie little LT1 radiator (without spending $679 for a USA made product) http://www.superchevy.com/how-to/070...vy-camaro-z28/
I have always subscribed to the thought that a larger radiator just prolongs the time it takes to heat up, but won't lower that final temp.
Heat transfer is the fastest when the temperatures of the air and the coolant have the highest delta. The hotter the coolant and/or the cooler the air the faster the heat energy will transfer from the hot coolant to the cooler air. The hotter your engine gets, the faster the radiator can cool it back down. Making the radiator bigger means there's more coolant to heat up, but it's only in the block for the same amount of time, and more time for the temperature delta at the radiator to equalize. That means cooler coolant being returned to the engine from the radiator and the engine still having the exact same amount of time to heat that cooler coolant back up. If the cooling capacity of the radiator and fans is sufficient for the coolant temps your targeting then it will maintain those temperatures. But if it's not, it'll just take longer for the higher than desired temperature to happen.
I hope I explained this so that it makes sense.
Installed a thicker all aluminum core radiator.
Ambient temp was about a 100* today and ect climbed to 220
Hit F it and bought a new ewp
