Quality 4340 Eagle Crankshaft ?
I hear nothing good about Eagle and how their cranks are cracking left and right. Is their reputation plagued with bad reviews like MSD is with their lower quality products; does the same situation apply ? Or is anything made by Eagle something to stay away from.
Check out youtuber MotoIQ. They use Eagle assemblies and do well with them. My old LT1 has a Eagle 383 kit in it. Engine is sold now and still running strong. Built it in 2007
There's nothing wrong with shopping and you're doing the right thing by asking. But in my personal experience, I never had any problems with them and all their stuff mic'd out dead on every time. And I mic everything.
Not to say someone else didn't have an issue. Every company does. Trust me, my luck is all bad luck. I've had more stuff wrong than right from companies.
HOWEVER
There was a "bad" batch made back in the early 2000's where tolerances were passable, but not the same as stock at least for pilot holes, flanges and the snout. The pilot hole and flange were oversized and the snout was slightly undersized. If you buy one, make sure these areas are checked before assembly.
eagle makes good stuff.
You will not regret it.
3600 stall and a turbo application would I even benefit ?
Not trying to change your mind. Just giving you the facts.
SBC & LT1's have a nice fat lower/mid range rpm torque curve that's very well suited for daily driving ... adding cubes ...to 383 or 396 just makes what was good...GREAT about the LT1.
I've racked up ~700,000 miles daily driving 3rd & 4th Gen F-body's....very little of that is higher than 5,000+ rpm...the high rpm stuff matters racing or having fun on back roads etc but not very much on the daily drive or kicking around town.
For a properly built 383 LT1, 6,500 rpm isn't an issue from what I saw back in the day. Finding a quality builder could be an issue.
There were three such 383/396 LT1's running around locally back in the day. Too much NOS killed one, too much boost killed another and the last was going strong at ~12+ years that kept the boost moderate.
There was also a pair of 396 LT1's thrown by parts slappers that came apart within weeks of being built.
I don't recall any issues at all with the trio of NA only 383/396 LT1's in my local club - other than an occasional new water pump and opti-spark. These cars were all high 10's low 11's and frequently drag raced. They were built correctly etc.
There are a lot of reputable builders that are only an hour drive from where I am. They all do fantastic jobs on the one or two things they do. Its just a bout a year or more wait time; common complaint I see but honestly its not too important.
They are incredibly reliable engines; I think the reverse flow cooling helped out too. It is crazy how the opti was almost the death of them. Thankfully, there are many ways around that issue, such as a coil on plug conversion kit, and with a carburetor, you wont tear your head out dealing with computer bs.
