when does torque peak in a stock LT1
Old Aug 31, 2004 | 10:23 AM
mikez28_mjf's Avatar
Default when does torque peak in a stock LT1
Just wondering at what rpm a stock LT1 makes max torque. Looking for the numbers for a 97 F-body.
Thanks.
Old Aug 31, 2004 | 10:26 AM
METALBEAST's Avatar
Thanks.
Rated 325 lb/ft @ 2400 RPMS (F-body)
Old Aug 31, 2004 | 10:41 AM
thanks!
Old Aug 31, 2004 | 10:54 AM
un4giv3n's Avatar
is peak torque that low in the rpm range good or bad?
Old Aug 31, 2004 | 11:29 AM
METALBEAST's Avatar
Peak torque occuring a low RPMs allows the car great "off the line" acceleration. This is the main reason for the common myth that LT1s have more torque than an LS1. The LS1 has more peak torque, but an LT1's peak torque occurs lower in the powerband.
Old Sep 1, 2004 | 03:30 PM
ShadowLvr's Avatar
325 torque? Did they squeeze out an extra 5 for the bigger B and D bodies? (96 Fleetwood claims 330 at 2400)
Old Sep 1, 2004 | 03:44 PM
John95Z28's Avatar
It's probably tuned different, with its own cam profile. If memory serves, the LT1 Caprice made 260 hp, which is 15 less than the single cat LT1 F-body
So there you go - more torque, but less hp
Old Sep 1, 2004 | 07:18 PM
ShadowLvr's Avatar
Yea, we're running 260 horse. So we traded a bit of torque for the horses.
Old Sep 2, 2004 | 06:38 AM
METALBEAST's Avatar
The cam for the B-bodies has a bit less duration on intake than on F & Y bodies, giving them more lowend torque than the F & Y bodies.
1994-1996 B-bodies (including L99 4.3L): 191/196 0.418/0.430 lift 111 LSA
Old Sep 2, 2004 | 11:56 AM
S8ER95Z's Avatar
The heads are different too..
Old Sep 2, 2004 | 12:24 PM
METALBEAST's Avatar
This is true the heads have larger combustion chambers than they do in the F & Y bodies and thus run 9.8/1 CR as opposed to 10.5/1 CR. The heads on the Bs are iron heads and as such, would have problems with detonation (spark knock) if they ran the high compression that the aluminum heads run.
Old Sep 2, 2004 | 04:13 PM
S8ER95Z's Avatar
hehe, figured I would add that in..didnt know if it had any direct effect on the trq/hp department.
