A/c delete
Old Sep 3, 2004 | 03:49 PM
WhiteBlur's Avatar
Default A/c delete
Where can I find a/c delete kit? Thanks
Old Sep 3, 2004 | 04:13 PM
bowtie9696's Avatar
I got mine from gmpartsdirect for around $30, and it uses the stock hardware and belt.
Old Sep 3, 2004 | 04:18 PM
BizZzatch350's Avatar
Moderator
I did the 1le pulley as well, thats the way to go unless you plan to relocate the alt to were the comp went.
Old Sep 3, 2004 | 04:24 PM
95_Firehawk_Dude's Avatar
I can get you a part number for the pulley and belt if you need it. I have it at home.
Old Sep 3, 2004 | 04:28 PM
Moderator
As long as you have stock pullies on the alt and crank, the stock belt works fine.
Old Sep 3, 2004 | 04:32 PM
Really? I needed a differant (smaller) belt.
Old Sep 4, 2004 | 04:58 PM
WhiteBlur's Avatar
If it's not a problem that would be great! Thanks
Old Sep 4, 2004 | 05:04 PM
AnthonyConstant's Avatar
what kind of hp we talking about
Old Sep 4, 2004 | 09:20 PM
Moderator
I have put about 5 of these pulleys on, unless you have after market pulleys, it will fit with the stock belt. It may be alittle pita like all belts are once these tensioners get old but its designed to work with the stock belt.
None, just gets rid of the ac, so you save a little weight, trust me its not a smart mod unless your ac comp took a dump and you dont have the cash flow to pimp a new one.
Old Sep 4, 2004 | 09:53 PM
thanks
Old Sep 5, 2004 | 04:10 AM
S8ER95Z's Avatar
Yeah my ac comp clutch locked up..shredded two belts before I finally got mine delete ordered. A new comp was a lot of $$$.
I did have one issue...if WOT and going thru a curve I would occasionally lose power steering *belt slippage* in higher RPMs, not sure if I had a weak pulley or not..but if you have any issues you can get a lil bit smaller belt to prevent that kinda thing.
Old Sep 8, 2004 | 11:35 PM
Parker TX's Avatar
ebay ebay ebay
