How Hard To Change Optispark??
Old Oct 9, 2004 | 12:28 PM
ZL1SS's Avatar
Default How Hard To Change Optispark??
As the title says, I think my opti is going out and want to know how hard it is to change it. Are there any tips to do this or should I just leave it to a shop to do. Also, where is the best place to get a new AC delco unit. Any help is greatly appreciated.
Old Oct 9, 2004 | 12:39 PM
Slow TA's Avatar
its pretty easy. ive done it so much that I can change an opti out in a hour. I would get a haynes manual or something if you have never done it before.
Old Oct 9, 2004 | 04:46 PM
LT1Burnout's Avatar
i agree with "slowTA".. its not very hard but if its ur first time i would recommend a chiltons or haynes manual and expect it to b a lil hassle. also, about the replacement unit.. i forgot the site, but some guy from LT1tech knows where to get em cheap (round $300.00). give me a few and i'll try and dig him up
Old Oct 9, 2004 | 06:09 PM
Fastbird93's Avatar
For a new opti go to Jason Cromer @ Samtaylor Caddilac. Parts@samtaylor.com or look on the website for the phone number.
Very easy to swap out, although I find the claim of a complete swap in an hour to be a little much. Maybe get the old one out in an hour, but not a full swap.
The ONLY things you need to remove are the air intake, water pump, crank hub, and opti. And drain the radiator. Easy job!
Old Oct 9, 2004 | 06:20 PM
taner's Avatar
8 Second 6 Speed Director
From: windsor, ont. canada - Home of the fastest LT1 6spd.
if you can turn a ratchet then you can dooo it!
Old Oct 9, 2004 | 10:34 PM
LT1Burnout's Avatar
thanx fast bird!! thats the place i was talkin bout..
Old Oct 9, 2004 | 11:53 PM
Y2kHawk05's Avatar
Autozone has the best deal on AC Delco remanufactured AC Compressor & clutchs. $209.99. I could not believe it myself. I just replaced mine and now think I am having opti problems. Some of the guys who posted to this thread gave great ideas for me to check.
Old Oct 10, 2004 | 12:24 AM
LFNDUST's Avatar
Default opti...
summitracing.com 280$
Old Oct 10, 2004 | 08:44 AM
Fastbird93's Avatar
I believe that's for a vented opti, which Jason Cromer sells for about $210-220.
