Spec clutches... good or bad??
Old Oct 24, 2004 | 09:34 PM
NXSLT1's Avatar
Default Spec clutches... good or bad??
Did some searching about spec clutches and the feedback seems mixed. Just wondering if I could get some feedback from yall on the subject. Are they good for the street or not? Do they last long or will I be replacing it in a year or two? I'm thinking about getting the Spec stage 2 clutch. The car will be a daily driver with weekend trips to the dragstrip.
Old Oct 24, 2004 | 09:45 PM
ls1fbod's Avatar
You would see more feedback under 'Manual Trans', but spec is a great clutch well up to 500 HP, and is very responsive...
Good Luck
Old Oct 24, 2004 | 10:30 PM
93turboLT1's Avatar
I love mine, I drive my car daily, its been great and hasn't slipped once. I drive like I'm at the track all the time so, i'm sure if your more conservative then the spec two will last you well past 2 years. I'm pushin 350rwhp so I give it two thumbs up
Old Oct 25, 2004 | 11:14 AM
roadtrip120's Avatar
I know a spec stage two hold a Cammed Lt1 with a 150 shot fine, even with a 1.6 60ft. Mine is on the way.
Old Oct 25, 2004 | 11:48 AM
Gangly's Avatar
i have spec stage 2 as well with a pretty good amount of HP behind it and it is holding up fine
Old Oct 25, 2004 | 06:02 PM
Slow TA's Avatar
ive had a spec stage 2 on my car for about year and its never sliped not once.
I have also sprayed on it several times
Old Oct 26, 2004 | 09:26 PM
NXSLT1's Avatar
Does Summit or Jegs carry the spec clutches?? I checked their catalogs and websites and they don't seem to carry them. If not then where are yall getting them from??
Old Oct 26, 2004 | 09:30 PM
SSmoky01's Avatar
Texas speed and performance (one of our sponsors) has a wide variety of clutchs, Spec being one of them of course check em out.
Old Oct 27, 2004 | 12:03 AM
93turboLT1's Avatar
Check out ebay, they usually run a few around 370, might save you a hundred or so. I bought mine from LMperformance and wished I know about ebay then.
Old Oct 27, 2004 | 07:44 PM
BottleFed383Z's Avatar
I have a spec 3 in my car and its fawkin awesome. Holds power and shifts hard. Dont have any problems yet
Old Oct 27, 2004 | 07:56 PM
02WS6Bird's Avatar
Speed Inc.... www.ls1speed.com one of our sponsors as well --->
Old Oct 31, 2004 | 02:47 AM
97M6Formula's Avatar
Wow you guys have had better luck than me...Spec 3 with 2500 miles on it and then one of the springs on the disc popped out and was causing a bad vibration but after spendin all my cash on things for the new motor I am left with one option...Buy another disc so hopefully this one holds good. But before that spring incident It was AWESOME grabbed like a SOB
Old Oct 31, 2004 | 10:34 PM
Gloveperson's Avatar
I have also heard some mixed results about Spec. I have not heard bad things about the Cartek clutch though. Just some food for thought.
-Todd
Old Oct 31, 2004 | 11:30 PM
cyphur's Avatar
McCleod clutches are pretty badass too. I have a Spec 3 right now, and it has a little chatter if I try to treat it like the stock clutch. Spec's S3 is more like a light switch than a dimmer(stock clutch) unless you're revvin a little higher. Then you can ease in. Grabs like a **** tho
Old Nov 3, 2004 | 11:32 PM
Fade2blk500's Avatar
Hats off to spec, really good clutch.
-Craig
Old Nov 4, 2004 | 09:05 AM
Gangly's Avatar
spec three is a serious clutch though, not meant for daily driven grocery getters. Spec 2 is optimum for that. spec 3 will chatter a lot if you treat it like a stock clutch
Old Nov 4, 2004 | 10:32 AM
Turnin'LT4's Avatar
In less than a year i went through two stage 3's. Right now i have a stage 4 with a billet flywheel and i love it. Much better than the stage 3. It grabs alot harder. The stage 4 has about 6 months on it. It is getting warn. It would last longer but i was caught in interstate traffic for 14 miles which was hell on that thing.
