MSD now makes a Opti crap replacement... HAIL
http://www.semaphotos.com/default.a4...M2004110228531
Wait a minute. I know what happened. GM paid them to hold off of the release of it until the got rid of the overstock of the OE opti's
Just for any b-body guys that may be reading the 94 b-body got the "95" and later vented opti.
I think the fact that the mainsteam aftermarket has not developed much in the way of opti replacements shows that it is not as bad as people make it out to be at least the vented ones are not. At 96K I swapped out my original and it turned out not to be the problem, now at a few hundred miles shy of 160K and no problems with the second, no way I would have eer left a gen1 cap and rotor in the car even the 60K+ my second opti has much less the 96k I had on the first. It was new and different those are the primary reasons it is "bad"
, with the slight hassle of change contributing to it's dislike, but really a WP is not the end of the world to pull. Trending Topics
So having a cap and rotor, hopfully at a fair price, will be great for all the dead ones I have. Except the four that lost res signals and bearings.
Now if it was just a little easier to replace
I can do a cap and rotor on my new setup in about ten minutes
Clearly not reading...
MSD GM LT-1 Distributor Cap/Rotor, 1993-94 PN 8481, 1995-97, PN 84811
I'm sure they are a lot better than the GM offerings or the NAPA replacements. Probably be made to handle a lot more RPM reliably than the shatter prone opti.
Ahh Tony J, don't be calling names, just stated you didn't read through it clearly. I'm not a jerk at all, i'm a nice guy hence the reason for posting up my findings for the LT1 crowd. I've watched the progress of you car on Cz28.com. Are you still running cogs BTW?? I didn't have any luck with cogs on my set up. I now run the SDCE 8 rib set up and haven't had a belt problem since
You have a nice ride and i've been to your site a million times. We are doing a 396 LT1 Vortech t trimmed powered Formula right now, should be pretty potent.Jeremy the jerk
j/k
Most people do not push the Opti's as far as the rest of us and that has a tendency to make a differance.
96capricemgr: My car see's 6,900+ on a regular basis...yours?
j/k
When I first looked at the link, I swear it didn't have the vented opti listed. I looked, because I was interested (even though I run the LTCC...) There is also a new products list on another site that has the SEMA announcement by MSD and they didn't list the vented version. I jumped to the conclusion...
Hopefully it's more affordable than the LS1 coil pack conversion kit that I see from time to time.
