fastest lt1 n/a with ac delco pcm?
I think it puts you:
#1 with stock pcm
#3 n/a lt1 overall,stock suspended f-body
nice runs down at thunder and nice to meet you...
We lt1's gave them a fit down there didnt we????
#1 with stock pcm
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#1 with stock pcm
We lt1's gave them a fit down there didnt we????![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#1 with stock pcm
Originally Posted by ou812/z28
awnser me this who has the fastest n/a lt-1 in a 4th gen with the factory pcm and harness. i think i do. i went 10.18 at 132 with a 1.38 60'.
so if any body knows of anyone faster let me know are do i hold this title. race weight was 3325 with me. also were does that put me on the n-a board overall. ![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
You ran that all motor??
David
It looks like your #4 on the N/A LT1 by a few hundreths of a second.
Dave Odehnal
1993 Camaro Z28
Ported factory LT1 casting heads and intake.
1/4 mile time:10.15 at 134mph
60 foot: 1.37
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Dave Odehnal
1993 Camaro Z28
60 foot: 1.37
#32
Originally Posted by FASTFATBOY
Can we have some pecs on this unit PLEASE??? Enquiring minds wann know what makes this unit tick.
David
David
made 467rwhp and 517rwtq. best pass to date is 10.18 at 132.
#33
12bolt 4.10gears,210afr heads, 1 3/4 super comp headers,cust cam from cam motion,eagle rotating assy, brodix hv=1 carb intake modified for efi and custom made elbow. th-350 12.5to 1 and the passes were made in street trim thru the mufflers. 3inch x-pipe and bullets turned down at the axles.twin 58mm throttle body.qa-1's all the way around. and all motor.
made 467rwhp and 517rwtq. best pass to date is 10.18 at 132.![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Thanks
David
#34
tune is a mixture of mike murrilo and futral motorsports.. 55lb injectors, after market rails, all aromotive fuel system, welded sump on fuel tank. and still have the old opti,
#35
Thanks
David
#36
Race fuel or pump gas? What is you injector duty cycle, have you logged it? Do you have to run an impedance converter for those 55's? Is your car red by chance? With a hole in the hood?
Thanks
David
Thanks
David
#38
9-Second Club
Originally Posted by TwoFast4Lv
HOW many on Stock PCM and 4l60E ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Hot Rod hawk has gone 10.60@130 with a 1.3x 60ft
Spraying a 4,000+ stall out of the hole with Juice!
Looked at Joe Overton's car. Heads, Intake, etc, are not LT1. Just the block & timing cover, I guess. Sure fast, though.
Want to mention what a gentleman Bejamin Moore is. When my tranny died Saturday morning at No Problem, he offered to drive an hour to get me a loaner. Not a lot of people like that around anymore. Want to thank him again. He's a good guy. Don't know what "name" he uses here.
Take care, Ed
#40
9-Second Club
Originally Posted by blackz93
joes car has LT1 heads on it..AFR 227's i believe?
AFRs aren't LT1s. Seems like they had parameter valve cover bolts. Could have been somebody else's. Aren't AFR LT1 valve cover bolts in the center?
Also had a 4bl intake & billet 4lb throttle body. Didn't look "very LT1". Looked more like an NHRA Comp Eliminator, Super Modified (single 4bl) engine with efi. Still very fast, just not what I expected.
Ed
